Deleted
Deleted Member
Post by Deleted on Apr 20, 2013 7:41:59 GMT -5
Hello, this is in continuation from this thread guitarnuts2.proboards.com/index.cgi?board=repair&action=display&thread=6778 where i idiotically tried to fix a 700+ USD guitar by fitting an abnormally peculiar chinese locking nut. In some episode i broke the nut wood screw into the wood. Pictures : it is seen on the pictures above, it's diameter is 2.5 mm, (about 6/64 inches). Now i am planing to go and buy a new Gotoh nut R2 (41mm width). Its hole spacing is similar to the Schaller. So the new screw will go just next to the broken one but not over it. Could i just get away by drilling/screwing just with an angle towards the neck, avoiding falling onto the broken one, instead of risking drilling just next by the broken screw. Alternatively i could try and remove the broken screw. Cyn1? what would you suggest?
Deleted
Deleted Member
Post by Deleted on Apr 20, 2013 7:46:36 GMT -5
Here i better indicate the screw's position :
Post by lunaalta on Apr 20, 2013 10:13:47 GMT -5
I'm no expert in these things, so feel free to offer better opinions...... My logic says, it would be best to try to remove the old screw, repair the damage and then start afresh and fit your new nut. Since, you could get into deeper 'sheet' by messing with the fitting of your new nut, without removing the old, making things harder to repair. It is always easier and faster to rectify errors earlier, rather than leaving them and compounding the problem for later. As to how to remove the broken screw....... well, I said I wasn't any kind of expert, but here goes. I'd mask off surrounding areas, then try to grab the end of the screw with a pair of strong wire cutters, being careful to only let them bite into the screw and not cut right through it. Once it protrudes a little you can get a better hold on it, perhaps with pliers/grips. Tip:I nearly always scratch some wax onto screws before putting them into wood, which makes them a/ go in easier without so much stress/heat/sweat and b/ come out easier, even after a long period of time, when corrosion/oxidation may have occurred. I'd be interested in others suggestions......
Deleted
Deleted Member
Post by Deleted on Apr 20, 2013 12:18:12 GMT -5
Gracias, Have you tried this with success? i guess i'd have to remove some wood around the screw right in order to make room for the wire cutter? right? Also why a pair of wire cutters ? and not a single one? or maybe i haven't understood correctly. In order to remove it I am thinking of smth like that : www.stewmac.com/shop/Tools/Routing_bits/Guitar_Screw_Rescue_Kit.htmlOr just drill around the screw and then plug in a wood dowel/plug and glue it with strong bison wood glue. About wax, many thanx, next time i drill and screw it will not be a 5 minutes job, i'll take my time to do it right (wax, etc..) and finally fix the guitar to play nice.
Post by cynical1 on Apr 20, 2013 12:37:39 GMT -5
OK, my daughter is getting married today, but I'll get back to you tonight on your options. In the mean time, stay out of character and don't do anything else.
Happy Trails
Cynical One
Deleted
Deleted Member
Post by Deleted on Apr 20, 2013 13:05:56 GMT -5
OK, my daughter is getting married today, but I'll get back to you tonight on your options. In the mean time, stay out of character and don't do anything else. Happy Trails Cynical One Best wishes man!!! all the best!!! i know of your solution with the metal steel plate, but nut height is an issue, with the depth of wood as is now under the nut, in order to have an adequate action, i must use only a slight shim of lets say 0.3mm - 0.5 mm (max). How thick should the metal plate (which then i would have to drill-tap as you said) ?? just thinking if i could just repair everything (remove screw and glue plug back in) and just install a top mount nut. Here is the nut i am most probably gonna order : g-jax.com/510/tremolo-units/tremolo-locknuts/fgr-2.htmlIn the meantime here is one for the occasion, (the first part only, the last one is not so happy) :
Deleted
Deleted Member
Post by Deleted on Apr 20, 2013 14:06:26 GMT -5
Just a clarification having to do with getting away without extracting the old screw : Schaller/Gotoh nut screws have an offset of 5.5 mm from the side of the neck. The broken chinese nut is located at 6.8, hence all my hope for getting away with it. if the gotoh screw has diameter >= 3mm (which i am afraid it will) then there will be contact.
Post by lunaalta on Apr 20, 2013 16:09:24 GMT -5
Ahhh, one of the quirks of the English language. Pliers are pairs, just like trousers. So, just one (pair of) pliers. Actually, I suggested wire cutters, since they would cut into the top of the screw remains, allowing you to spin the screw out. Use them vertically, as opposed to parallel to the head. Just try to nip the top of the screw enough to get purchase to turn it out a little at a time. Shouldn't do too much damage to the wood. Well, not as much as has already been done, anyway.... That's a neat tool, from Stewmac, looks like it would do the job nicely. I work, mostly, as a builder/decorator and have had to use this technique many times in the past. Sometimes it's not so pretty afterwards, but the job gets prettied up afterwards. Seems like cynical1 has some input, so, I'd wait to hear from him before you proceed, if you can, that is.... Hope you have a great day, cynical1, daughter's weddings are fun, expensive, but fun.
Deleted
Deleted Member
Post by Deleted on Apr 20, 2013 23:23:57 GMT -5
luna, problem is the screw's top is dead flat with the wood. How could the wire cutter get the initial grip on this? Should i just dig a small circle around the area first? Its so dead flat you can it in the 2nd picture.
Aesthetics is not my problem at all. This guitar already looks mean and ugly, since the day i bought it. My problem is for the wood to remain strong.
Just a question, as a builder-decorator, what is your opinion about stew-mac and other similar tools? Would removing / plugging a 4.7mm dowel make an impact in the headstock's durability? I know i screwed up big time with this guitar, as can be seen from the pics, but every time i tried to compensate with more wood, fill with dust wood where originally there was no wood, etc... (described in the first thread i am referring to in the beginning of the 1st post).
Post by cynical1 on Apr 21, 2013 1:23:10 GMT -5
OK, I'm back. Long day...and I'm dog sitting...but that's another story.
Now, onto the matter at hand. If it were me, I would leave the sheared screw right where it is until the new nut arrives. Pulling it now is just fixing a problem you don't know if you have yet.
If the new nut arrives and the new holes miss the existing screw just leave it there. It's not hurting anything. Especially if it's sheared flat with the nut shelf routing.
If you have to remove the screw I'd use a screw extractor. If the screw is brass it'll drill easily and should come out with little drama with the proper sized screw extractor.
And using a bar of soap to scrape the threads against works good to remove some of the resistance screwing into hardwoods. Been doing it for decades and it works like a charm.
So, long and short of it, you don't have a problem now, so you don't need to do anything with the sheared screw. If the new nut mounting holes miss the screw, you don't have a problem there either. The odds are in your favor you won't have to do anything.
And thanks again for the good wishes. The wedding went well and they're off on their brief honeymoon...which explains why I'm watching dogs...
Happy Trails
Cynical One
Post by newey on Apr 21, 2013 1:26:06 GMT -5
Well, we should all wait for Cyn1 to chime in. But I suspect he's going to tell you to get, and use, a screw extractor like this one, which is good for screws down to 3 mm- which looks like what you're dealing with. This is a pricey option, though. If it's smaller than 3mm, even an extractor probably won't work, and you'd just have to drill it out- tricky to do with a small screw, though. You'd have to use a very tiny twist drill, like a jeweler's drill, and drill into the very center of the screw. Then move to a slightly larger bit to drill it out. But, again, let's await further explication.
Deleted
Deleted Member
Post by Deleted on Apr 21, 2013 2:17:45 GMT -5
Cyn1, glad it went well. Your daughter's husband is lucky to have you around (especially if he is into stringed instruments) I will order the new nut today, i also hope it will end up just like you said, and i initially hoped. Schaller and Gotoh screws are massive compared to the tiny chinese cheapo ones. Lets see how it will turn out. Just a question : what will happen if there is marginal contact of the screws? Will it affect the efficiency of the grip?
Newey, thanx for the tip, seems wood extractors are a bit pricey, but will keep in mind. When i get the new nut i will open a new thread with full review.
Post by lunaalta on Apr 21, 2013 3:59:37 GMT -5
Wise words from the cynical 1 GD, I haven't bought anything from Stewmac, so I can't give an opinion. Looking forward to see how this pans out....... Peace!
Post by newey on Apr 21, 2013 8:29:15 GMT -5
Aha, I see Cyn1 returned a few minutes before I completed typing my post.
Yes, the new screw will need to sit completely clear of the old or you will have a problem.
I have ordered from Stew-Mac several times. Their customer service is very good, in my experience. And they have many things that you simply can't find anywhere else, like the copper shielding tape with the conductive adhesive. Often, though, for basic guitar hardware items like screws and other bits, they are very expensive compared to other online suppliers.
Deleted
Deleted Member
Post by Deleted on Apr 21, 2013 8:42:11 GMT -5
As i have "dry-run" tested with the old schaller (the original left handed) the situation is marginal, so chances are 50%-50% i might go out for an 2.5mm screw extractor. Anyway i'll wait till the gotoh arrives, and then i'll try to drill and see what comes up. Ibanezrules.com says that one should give a slight angle of the drill direction towards the neck-side. In this case i might get away with this. lets see.
Post by cynical1 on Apr 22, 2013 1:45:33 GMT -5
...Ibanezrules.com says that one should give a slight angle of the drill direction towards the neck-side. In this case i might get away with this. lets see. ...and my mother said their was a Tooth Fairy... There's a countersink for a flathead screw on the nut, right? Is it offset for a slanted hole? I'd bet money that it's not. Find a drill press, use a fingerboard sanding block to center the neck and use some 3M blue tape to secure the neck to the sanding block. Secure the sanding block and neck to the table on the drill press, preferably with a drill press vice, and make sure the nut shelf is square and level by cross checking with a bubble level. Next, drill the mounting holes straight. Man, the crap you read on the Internet... As far as removing the screw, wait until the new nut arrives. Cross that bridge when you come to it. Happy Trails Cynical One
Deleted
Deleted Member
Post by Deleted on Apr 22, 2013 2:59:22 GMT -5
There's a countersink for a flathead screw on the nut, right? Is it offset for a slanted hole? I'd bet money that it's not. I pretty much suspect the same. i'll check with the old schaller when i get home. Find a drill press, use a fingerboard sanding block to center the neck and use some 3M blue tape to secure the neck to the sanding block. Secure the sanding block and neck to the table on the drill press, preferably with a drill press vice, and make sure the nut shelf is square and level by cross checking with a bubble level. Next, drill the mounting holes straight. As far as removing the screw, wait until the new nut arrives. Cross that bridge when you come to it. Happy Trails Cynical One From all the above a i have the drill and the sanding block 9.5 radius. Since i have no clamp, no drill press, what should i go for? I have only a regular Bosch drill, with various drill bits for walls, concrete, wood, etc.. with no other accessoires, no drill table, no base for the drill. Can you please give me some pics of all relevant additional tools and their english terminology ? then i will try to find the greek words and go to a good hardware store i know, where i could possibly find them. So, just to recap the new lessons learned here : 1) wait till the nut arrives, dont do nothing in the meantime 2) drill vertically to the surface, using the appropriate setup (drill table, drill press, drill press vice, etc... even if i need some clarifications on these) 3) always use soap bar to make the screw lubricated into the wood thanx a lot, i am determined to do it right this time : SLOWLY and carefully.
Post by cynical1 on Apr 22, 2013 10:07:33 GMT -5
OK, I feel your pain in regards to a lack of proper tools for the job. You have two options. You can find a friend with said tools, or try and wing it with what you've got. Keep in mind that your results will be a direct reflection of the tools used to perform the job. Use the proper size bit for your screws. Any high speed steel drill bit will work as you're only drilling into maple. A metric drill chart would be handy, but I found this in a hurry: Size the new screws and use the proper size bit according to the chart. I normally wrap some masking tape on the bit to mark the depth I want to hit. Drilling through sucks. With all of the Asian import tools out there you could probably score a small drill press for cheap. Buying it used drops the price even more and may get you into a higher end tool for the same money. I don't know if they have them over there, but we have a handy little cheater device that turns most hand drills into a drill press. These can run between $50.00-$100.00US I used to have a hand drill press I picked up at a flea market for $10.00. It was similar to this: I used it primarily for drilling the small screw holes for tuners, but it would work for what you're doing. God only knows where you'd find one these days for under $100.00US... A small vice is all you're looking for. These are always available at garage sales, flea markets or classified ads. I still have a heavy duty anvil vice that's about 80 years old that I scored for $15.00US at a garage sale. This thing will survive the Apocalypse and the it's still tight as a new one...you can even flip the jaw plates from smooth to serrated. This may be overkill for you, as the thing weighs close to 100 pounds (45kg) 1) wait till the nut arrives, dont do nothing in the meantime Correct 2) drill vertically to the surface, using the appropriate setup (drill table, drill press, drill press vice, etc... even if i need some clarifications on these) Correct 3) always use soap bar to make the screw lubricated into the wood Correct, but the tip lunaalta mentioned on using wax is equally as valid. Very important. Any more questions? Happy Trails Cynical One
Deleted
Deleted Member
Post by Deleted on May 8, 2013 16:10:45 GMT -5
Guys (Cyn) i need help.... so i got a mobile drill press, like the one cyn posted, and a drill press vice... thing is, i dont know how to attach the drill press vice to the base.... the ppl at the store, after trying to explain to them their own product for about half an hour, finally sold me some bolts that are totally useless.... i am gonna return the bolts to this store tomorrow, i just dont know what to buy.... spending an other painful 1 hour there without results would be fatal.... The stand is this : www.wolfcraft.com/en/products/p/drill_stands/1_drill_stand-1/s/p/index.htmlVice : www.wolfcraft.com/en/products/p/vices/1_simplex_60_vice/s/p/index.htmli know it must look like a normal hexagon bolt from the upper side, dont know about the bottom. Also length is crucial....
Post by cynical1 on May 8, 2013 16:36:06 GMT -5
well, from what I see it attaches like most drill vices. This is from their website: You are correct in that if they gave you the wrong bolts it will be a challenge to make it work. HTC1
Post by sumgai on May 8, 2013 18:03:52 GMT -5
gd,
On the "under side" that we don't see, the nut should be sitting on a large washer. That provides strength so that the nut stays tight where you put it, and doesn't try to move along the open line of the slot. If you're buying bolts/nuts from a store that did not sell you the press and/or vice, then take the whole thing with you next time.
HTH
Deleted
Deleted Member
Post by Deleted on May 9, 2013 0:00:33 GMT -5
Cyn thanx. SG, that's exactly what i am gonna do. I am going to a store, that i know for sure they dont sell mobile drill press stands and vice, and tell them, that i had no option buying from them. I think they will help me.
Just a note drill press stand cost about 37 EUR, and vice 17 EUR.
Deleted
Deleted Member
Post by Deleted on May 9, 2013 2:05:04 GMT -5
i think its gonna be ok, i went to the very store i bought the two items (drill press stand + vice) and after engaging into a fight, i managed to meet the manager who also comes from around my village up in north-west Greece, who managed to find some solution with wing-nuts, + ordinary bolts 8mm diameter (hmmm or maybe i helped him find a solution). He gave them for free, despite asking him to be charged. I still haven't figured out why Wolfcraft do not sell the mounting harness as a separate part. It was not a pleasant morning at all.... Now back to work.
Deleted
Deleted Member
Post by Deleted on May 9, 2013 6:10:32 GMT -5
Post by sumgai on May 9, 2013 11:38:33 GMT -5
gd, Glad you got it worked out, even if meant some nasty moments with unfeeling store employees. And Irwin is known for making better quality tools, so that extractor should last you for a long time... unless you have to use it several times a day! sumgai
Deleted
Deleted Member
Post by Deleted on May 9, 2013 14:16:19 GMT -5
Man this guitar is gonna screw me.... I mean, THIS is my dream, to make *this* work. Not the partscaster strat. The strat is fine as is, always plays good, no matter what the load/fatigue. Its the carvin which drives me crazy....
