Post by nickbachman on Jun 26, 2006 20:57:25 GMT -5
greetings. I'm in dire need of help. I recently replaced the HB in my Fender Jag-Stang with a GFS Bigmouth 4-wire. I'd like to make the HB's 3-way switch work as:
(bridgeside).......|Full HB|---|Off|---|Split HB|.......(neckside)
can i wire it that way? split with the 3-way switch instead of a push-pull pot?
Post by Mike Richardson on Jun 27, 2006 4:44:39 GMT -5
Is it the one with 8 solder lugs on it?
Post by nickbachman on Jun 27, 2006 11:22:50 GMT -5
yep
Post by Mike Richardson on Jun 27, 2006 16:36:56 GMT -5
A is where the pickup's hot wire goes, B is where the two wires that are normally connected and taped up should go. A is towards the bridge. The arrow is the wire to the volume pot.
