gator
Post by gator on Aug 10, 2006 17:22:16 GMT -5
Okay...So I have everything going to central ground. This morning I tried it without my main tone control grounded (the one with the large ring connector). It sounded good granted it was 6am and couldnt really crank the amp. I came home today to work on the final piece which is my "super tone control" that cuts/boosts midrange. I disconnected one capacitor from the pot shell and ran that to central ground. Then I disconnected the inductor from the top of the pot shell and ran that to the central ground. The inductor is connected to the pot terminal by a cap. Plug the guitar in and I am getting a pretty good amount of hum. Should I have not disconnected the inductor? Hum is not affected by touching anything like strings, nobs, guitar chord, etc....well except swithing to the humbucking positions 2 and 4. The only thing that has changed since this morning is I added another wire to the central ground for the inductor, then connected the inductor and other cap to the central ground with their own individual wire. As far as I can tell nothing in the circuit is touching the copper tape. I am sooo p d that I didnt crank the guitar up this afternoon to try it before messing with it again. Then I would know for sure. Oh and I put electrical tape accross the top of the pot shell so the inductor wouldnt touch it. It is "floating" above the pot shell.
gator
Post by gator on Aug 10, 2006 17:49:47 GMT -5
Well I just approximated where I had the amp volume this morning and it was pretty quiet....maybe this is just the nature of the beast...no pun intended. But seriously if you guys have any checks I should run through I would appreciate it. I know one commom problem is hooking up the input jack wrong. I checked and I have the ground/black wire running to the outer ring and the white going to the prong that runs to the inner ring. Anything else I should check?
Post by UnklMickey on Aug 10, 2006 17:56:25 GMT -5
a couple of possibilities come to mind. 1 -- you had just as much hum before, but didn't notice because you didn't crank it up. 2 -- you accidentally broke the connection to your string ground. Hum is not affected by touching anything like strings, nobs, guitar chord, etc....well except swithing to the humbucking positions 2 and 4.
gator
Post by gator on Aug 14, 2006 14:24:34 GMT -5
Thanks, I have gone back and tried few things and its not as bad as I initially thought. Actually its really not bad at all. I can turn my Epi Valve Jr up to 12 o'clock with not significant noise increase when going from position 2 or 4 to the other positons. It really doesnt start to become evident until at least 1 o'clock. I think its just the fact that I have gone from a Sey Duncan Hot Rail humbucker to high output single coils. So I was used to no noise at all in the bridge position.
