cmgarst
Post by cmgarst on Sept 19, 2006 22:24:49 GMT -5
I Need Somebody To Help Me I Have An EMG 81 85 And HA That I Need To Wire With A 5 Position 6 Pole Rotary Switch. Each Pickup Will Have A Volume And There Will Be A Master Tone I Would Like To Wire The Rotary Switch So That Position 1=Bridge Pickup Position 2=Middle Pickup Postion 3=Neck Position 4=Bridge+Neck Position 5=All Pickups
Could Anybody Help ME?
Post by UnklMickey on Sept 20, 2006 12:56:36 GMT -5
hi Cmgarst,
welcome to Guitarnuts2.
that doesn't sound like it would be too hard.
you have twice as much switch as you need. (you'll need 3 poles.)
having the tone control after the volume pots won't be great, but it's the only way, when you have individual volumes, and a master tone.
you can have the volume controls "forward" (better individual control, but if one volume is set to zero, and selected, it silences everything).
or "reversed" (controls are independent).
i could draw you a schematic, but not an actual wiring diagram.
can you read a schematic?
unk
ps, those pickups are going to take a lot of real-estate.
why did you choose the HA for the middle?
