Post by spitfire23bc on Oct 16, 2006 18:26:06 GMT -5
Is it possible to wire a dp5t switch with two pickups so that it gives: - 1 pickup - the other pickup - both in series - both in parallel - bypass both pickups
Post by ChrisK on Oct 16, 2006 18:54:15 GMT -5
If it's a true DP5T switch, yes.
If it's the Fender type (which ain't a DP5T but a DP3T shorting with extra detents), don't know.
Post by spitfire23bc on Oct 17, 2006 4:49:26 GMT -5
If it's a true DP5T switch, yes. If it's the Fender type (which ain't a DP5T but a DP3T shorting with extra detents), don't know. Hmm yes it is the Fender switch
Post by flateric on Oct 18, 2006 9:55:27 GMT -5
I am interested in doing similar (but not the bypass) with 2 humbuckers, a 5-way strat switch and a psh-pull coil tap pot, to get as many interesting and usable tomnes as possible. I suspect I may need one of those superswitch chappies.
Post by ashcatlt on Oct 19, 2006 13:02:17 GMT -5
I don't believe it will work with the standard strat switch. You will need a 2p5t switch. It'll have 12 terminals on it. You could wire it like this. That's a 4-way switch (2p4t), but for your kill position I think you can just leave the extra terminals unconnected. Musician's Friend has a 2p5t replacement for the strat lever switch for not cheap. Others might be able to provide links to other sources. Most around here will probably tell you to get a superswitch, which is a 4p5t, and I think costs about the same.
Post by spitfire23bc on Oct 21, 2006 5:30:27 GMT -5
I don't believe it will work with the standard strat switch. You will need a 2p5t switch. It'll have 12 terminals on it. You could wire it like this. That's a 4-way switch (2p4t), but for your kill position I think you can just leave the extra terminals unconnected. Where are the poles on that dp4t switch? I've been trying to understand what's going on but I can't seem to get my head around it..!
Post by ashcatlt on Oct 24, 2006 15:30:41 GMT -5
It is kind of crazy actually. The "poles" are on either side of the switch. The "common" for the left-side pole is at the bottom, with the common for the right-side at the top.
I'll come back later tonight maybe and go through tell you what's connected in each position. Right now I have a 3yr old crawling all over me.
Post by ashcatlt on Oct 24, 2006 15:47:23 GMT -5
Okay, got him distracted. Let's see if I can get through this...
I'm going to call the hot and ground from the pickups + and -, respectively. Hot will be the tip of the output jack (via volume control) and ground will be the bridge/jack ground.
1) both + to hot, lead - to ground, rhythm - to nothing. 2) both + to hot, both - to ground 3) rhyhtm + to hot, lead + to nothing, both - to ground 4) lead + to rhythm -, rhythm + to hot, lead - to ground
on a 2p5t switch, if you leave position 5 empty on both sides you'd have: 5) lead + to nothing, rhythm + to hot, lead - to ground, rhythm - to nothing no continuity anywhere, so a kill position. You can put this anywhere you want on the switch, of course.
Post by UnklMickey on Oct 24, 2006 16:28:50 GMT -5
ashcaltlt, here's a picture of a 4P5T switch, to help with your description. for a 2P5T, just ignore the rear wafer.
Post by ChrisK on Oct 24, 2006 17:11:28 GMT -5
Post by ashcatlt on Oct 25, 2006 0:11:46 GMT -5
In the picture we were talking about the positions on both sides are numbered from top to bottom. You can change these around to get a different order if you think it's necessary, just make sure you make the same change on both sides of the switch.
Post by spitfire23bc on Oct 25, 2006 9:23:56 GMT -5
Ahhh [understanding dawns]
Thanks Ashcatlt (+1). Presumably it isn't possible to get the 4 settings on a strat switch? (as opposed to those plus a kill switch)
Post by ChrisK on Oct 25, 2006 12:01:34 GMT -5
Sure, as long as it's a Strat super switch (4P5T).
Post by ashcatlt on Oct 25, 2006 13:50:04 GMT -5
Sure, as long as it's a Strat super switch (4P5T). ...which means no. If you look at a strat switch (there's one in the link chrisk posted above) you'll see it's only got 3 real "positions," or terminals other than the common on each side. These are positions 1-3-5 on the switch. 2 and 4 short the terminals adjacent to them together. I wanted to mention too: The link I gave shows a connection from the metal case on the neck pickup to ground. If you're not using a tele, you probably won't have a metal cover on your neck pickup, so you can ignore that connection altogether.
Post by spitfire23bc on Oct 25, 2006 15:11:13 GMT -5
Sure, as long as it's a Strat super switch (4P5T). ...which means no. If you look at a strat switch (there's one in the link chrisk posted above) you'll see it's only got 3 real "positions," or terminals other than the common on each side. These are positions 1-3-5 on the switch. 2 and 4 short the terminals adjacent to them together. I wanted to mention too: The link I gave shows a connection from the metal case on the neck pickup to ground. If you're not using a tele, you probably won't have a metal cover on your neck pickup, so you can ignore that connection altogether. Yeah I wasn't holding out much hope - looks like I'll need a new switch! I'm not sure if I'll implement this any time soon; it was more of a point of interest... I'm thinking of using the DP5T to have the five options first mentioned, ie: neck, neck+middle (parallel), middle, neck+middle (series), bypass ...and then use a DPDT switch on a push-pull pot to change between adding the bridge pickup in series/parallel. There would be a need for some sort of bypass on this, in order to turn the bridge pickup off, so the guitar would end up with two volume controls - one for the middle/neck pickups and one for the bridge, which would hopefully give some nice blending potential. Just a thought that's been kicking around for a little while.
Post by ChrisK on Oct 25, 2006 17:55:43 GMT -5
Post by spitfire23bc on Oct 27, 2006 7:37:02 GMT -5
True, although this was more an exercise in what I could achieve with parts I currently have (not the way to seriously go about modifying a guitar I know, but at the moment it's really more of a point of interest). It's something I'll bear in mind though...
Post by ashcatlt on Oct 30, 2006 1:08:46 GMT -5
after struggling with the thing for almost 14 hrs straight I can tell you that my suggestion to leave the "extra positions" open doesn't work.
I was actually trying to do this with each of three single sized hb's in a strat, but in my troubleshooting I did test it with two seperate singles. When I had it wired up the way I suggested above I still got sound out of the "kill position." It was significantly quiter than the other positions, but quite distinctly still there.
After spazzing out and rewiring the thing 6 times, I finally came to the solution of shorting both coils in the kill position. Basically you've got to run position 5 on the "hot" side to signal ground and on the "ground" side to the signal hot.
Anybody got any ideas why? When I checked it with my meter, there seemed to be infinite resistance between hot and ground in the original configuration, but it still made noise!
Post by ashcatlt on Nov 6, 2006 13:04:13 GMT -5
I can now say that I've done this successfully 4 times. Once for each of the 3xHBs on my strat, and once for my LP Studio.
I think i might have reinstalled the bridge pup in the paul backwards, but the series position still sounds pretty crazy.
The LP now has a master vol, master tone, and a "blend" knob which acts as a neck volume in parrallel mode and a master vol in series mode.
Next time I get to my studio I'll be doing this to my Rick 330.
