kii
Post by kii on Nov 17, 2006 18:19:19 GMT -5
Hi folks. I'm working on a project Ibanez guitar at the moment, and I've finally made my way to working on the electronics and I need some quick advice. I'm going with an H-S-H setup, vol and tone, 5-way switch, and a DPDT On/On switch that splits the bridge and neck pickups. My goal is to wire the guitar like an Ibanez JEM, but with star grounding and the toggle switch. I worked out a quick "schematic," but I wasn't sure if it'd work. Any advice would be great.
kii
Post by kii on Nov 19, 2006 23:11:24 GMT -5
I generally don't like to bump my own threads, but can anyone help me out?
Post by flateric on Nov 20, 2006 2:52:35 GMT -5
Wow, that looks like my gran's knitting basket. If you could unravel all the wool someone might be able to dcypher your diagram, or produce an orderly schematic instead, it's pretty hard to visualise as-is.
Post by UnklMickey on Nov 20, 2006 8:47:30 GMT -5
hi Kii,
welcome to GuitarNuts2.
looks like auto coil splitting in positions 2 and 4, and another switch to force a split (to get single sounds in positions 1 and 5).
the blue wire to the tone pot is in the wrong place. it should connect to the other lead of the cap.
cheers,
unk
kii
Post by kii on Nov 20, 2006 11:19:48 GMT -5
the blue wire to the tone pot is in the wrong place. it should connect to the other lead of the cap. Oh. Yeah, I wasn't too sure about the placement of the tone wire. Thanks, that clears it up.
monradon
Post by monradon on Dec 6, 2006 17:58:56 GMT -5
unklmickey you mean it should be grounded right so it has a signal path ??
Post by UnklMickey on Dec 6, 2006 18:22:50 GMT -5
the ground is connected to the cw lug of the tone pot, and the hot is connected to the wiper.
the cap isn't connected in series.
one of the connections to the tone pot needs to go through the cap.
