Post by jimijunior on Nov 27, 2006 7:41:30 GMT -5
www.suhrguitars.com/pickups.aspxAny ideas on this lads? For that amout of cash it better work! Downside: "The BPSSC requires the middle pickup to be the same polarity and the same direction winding as the bridge and neck pickups. Reverse-wound reverse-polarity middle pickup will not work with the BPSSC." So that means I can already forget about it.
Post by ChrisK on Nov 27, 2006 19:27:41 GMT -5
I think that there is a RW coil built in to the vibrato cover plate that is used to counteract the Normal Wound pickups hum. Any RWRP pickup used will have about twice the hum as without this system.
As a result, all pickups used have to have the same winding direction, and I would assume that the connection of the aforementioned cover is reversible to match such winding.
