Post by shadowcastaz on Jan 8, 2007 17:50:25 GMT -5
I wiring up a bass project and I have a delema. I have 2 HB's with 2 wire(So tap coils are not an option) each. I had the control plate made and the only cut I had them make was for a 3 way blade switch. I decided to do 2 volume/1 tone control. How do I incorporate the 3 way blade switch and 2 volume pots? Thanx,Mike
Post by ranchtooth on Jan 8, 2007 19:05:45 GMT -5
2 Pickups with 2 volumes nullifies the use of a switch, in my opinion. I'd just save yourself the trouble and leave it out.
Post by sumgai on Jan 8, 2007 23:13:58 GMT -5
shadowcastaz, to these here forums! ranchtooth points out that you can fade between two pickups by merely manipulating the two volume controls - this is how the Jazz Bass has been doing it since, what, 1961 or thereabouts. But a switch is OK, if you perceive that you'll benefit from faster switching action. If you have a three way switch, you can only get a parallel combination or a series combination of the two pickups, but not both (unless you give up one of the single pups as a selection). Decide which way you wanna go, and soon enough, a diagram will appear. (Hint: The stock Jazz Bass configuration has always been in parallel. IMHO, a series combo will be darker, and less well defined.) HTH sumgai
Post by shadowcastaz on Jan 9, 2007 8:40:39 GMT -5
Parallel is my preferance,may be no switch! However I do like a challenge.Thanx .
