dnajemnik
Post by dnajemnik on Jan 21, 2007 19:01:30 GMT -5
I'm brand new here and I suspect that this has been discussed often. I have an HSS Peavey with non-original pickups. The two singles together have a fair amount of hum that disappears when I touch the strings, bridge, or jack. The humbucker does the same but the hum is a bit less annoying. Any suggestions?
Post by gfxbss on Jan 21, 2007 22:43:59 GMT -5
sounds like you have a ground loose. also, i would suggest sheilding your pup cavities and wiring cavity, also the back of the pickguard(if this axe has one.) may i suggest following this. at any rate, make sure there are no ground loops, and make sure that all grounds are connected securely. Tyler
ang3lus
Post by ang3lus on Jan 22, 2007 2:27:41 GMT -5
I had the same problem, i turned the guitar upside down till i found out it was the Ground disconnected in the amp jack (the one that goes into the wall, dunno how you call that in english, jack outlet ? heeh).
best choice would be to check with a multimeter, put the black on the bridge (flooyd, trem whatever you got, or the strings) and the red one on the ground inside the guitar, see if there's a connection, check pup's ground also, but if it doesn't happen with other guitars, i'd check my amp.
