Post by animainmachina on Jun 16, 2007 23:54:28 GMT -5
Hey all, I've spent hours trying to search this forum trying to find a solution to this, plus my understanding of guitar wiring is limited at best. But i am trying to find a schematic for a push-pull mod to turn on the neck PU in any position, at least one that's suitable for HSS equipped strats (all the mods i've found are for SSS only it seems)
Post by UnklMickey on Jun 17, 2007 0:41:29 GMT -5
Hi animainmachina,
Welcome to Guitarnuts2.
What you're asking for is either simple, or dead-simple. It depends on what you mean. If you want the push-pull to give you JUST the neck pickup and ignore whatever else is on the 5-way, that's fairly easy. If you want the push-pull to ADD the neck pickup to whatever is selected on the 5-way, that's even easier. You will just be needing the push-pull and 2 additional wires.
Tell us what you mean, and any one of a number of guys here can help you.
cheers, Unk
Post by animainmachina on Jun 17, 2007 6:19:33 GMT -5
Sorry I wasn't clear there. But I want the push-pull to add the neck PU to whatever is selected on the 5-way.
Post by JohnH on Jun 17, 2007 6:35:17 GMT -5
This is a typical wiring for a neck on switch: It would be the same on an HSS as for an SSS good luck John
