Post by sneakymarco on Jun 28, 2007 1:57:47 GMT -5
Hi all. I found this forum through the guitarnutz site and I'm hoping some of you might be able to help me troubleshoot a problem I'm having. First, I want to say that I've been taking my guitars apart for about ten years, however I had absolutely no idea what the hell I was doing until very recently, and basically just worked by trial-and-error, and exclusively with electrical tape (I thought soldering irons were mystical tools reserved for people who'd gone to school for electrical engineering). So, I don't know too much about all this stuff yet.
I have followed the instructions for shielding/star grounding my strat, to the letter (I think), yet I can hear no noticeable difference in the amount of noise I get when I plug it in.
The type of noise I'm getting is mostly directional, increasing and decreasing as I turn around, with some small reduction when I touch the strings/bridge/jack. I've tested the same amp and cable with another guitar which is unshielded, although has metal pickup covers. The noise is present with my second guitar, but only barely noticable.
I am thinking that this may be a grounding issue. My multimeter tells me that all of the interior shielding is continuous, however I do not have a completed circuit between the shielding and my isolated star ground. I've determined that the cap which runs from the shaft of the tone pot to the star ground is breaking the circuit.
Again, my understanding of this is limited, but isn't the point of star-grounding (or grounding in general) supposed to be that all of the grounds are introduced to the cable's negative lead, then to the amp? That's how all of the interference is taken from the shielding and dispersed instead of being introduced in to the signal? So if the shielding/grounding itself is not connected to the (-) lead of the cable (as seems to be the case here), then no actual grounding or shielding is happening; correct? Please correct me if I am wrong.
Anyway, when I discovered that this was happening, I tried bypassing the cap with a wire (just shoved/lightly twisted in to place; not soldered), but that didn't seem to have any effect. I suppose that wire may have come loose when I plugged everything in to test it... I've done way too much soldering today and really didn't want to fire up the iron again right then.
If it matters, the cap is an Auricap .33uf, 450v metal film.
The other theory I have is that it might have to do with my exposed pickups. However, as there is basically no reduction in noise pre- and post-shielding, I don't think this is the entire problem... Even if my pickups were picking up (!) some noise, shouldn't the fact that I've shielded my control cavity have at least some positive effect?
Any help that anyone here can give me will be much appreciated! I started out just wanting to shield my crappy old Mexi strat, and somehow wound up spending hundreds of dollars on a new body, new pickups and hardware and electronics, and now I've got everything assembled and wired and shielded, after literally months of waiting and work, but it's still noisy as all hell.... I'm getting so frustrated I'm about ready to just put the thing in my closet and forget all about it.
