ixelion
Post by ixelion on Jul 29, 2007 12:39:56 GMT -5
Okay, a while ago I had and Epiphone LP Studio and a Marshal MG 15W I was not having any technical problems at that time.
Recently I have swapped the Marshal for a Roland Cube 30W and now I get the most annoying sound (I am still using the LP studio)
Every time I lightly touch a string I hear a "pop" or a "click" this happens when I touch any metal part of the guitar not just the strings.
I tried using an Ibanez SA on the Roland and I got the same clicking, popping sound but it was quieter.
I also plugged the LP into a Fender Frontman 15W, and it only popped and clicked a bit but not nearly as much (or as loud) as the Roland.
The Marshal didn't pop or click with any guitar.
An email to Roland suggested a grounding problem, I have tried using different cables and plugging it into different outlets (although in the same house).
So here is what I suspect:
There is something wrong with the pickups on the LP (but the Ibanez clicks a little too so I don't understand) - fix or replace the pickups?
There is something wrong with power outlet, and I can hear the popping in the Roland because it has higher wattage than the Marshall or the Fender (30W vs 15W)? - whats the solution for this?
There is something wrong with the Roland? In which case I would have to get it fixed/replaced.
The popping is fairly loud on low volumes, but with the Ibanez you hear popping only when the volume is cranked.
Also would a noise suppressor get rid of this popping, clicking?
Thanks for any advice.
Post by DarKnight on Jul 30, 2007 17:58:07 GMT -5
Does this sound like it? I hear some popping/clicking on my guitar when tapping strings/bridge or other metal parts... Maybe that, or then it's just some ground problem prolly... Somebody else can give better advice on that. Good luck mate! Dark
ltb
Post by ltb on Aug 2, 2007 20:08:56 GMT -5
Went I first got my used EPI LP Studio it seemed to do that. I have since put Gibson Classic 57 pickups in it and do not experience that. Maybe there is something to what you say about a problem with the pickups. GFS (Guitarfetish.com) sells some decent pickups at a very good price.
