mattdavios
Post by mattdavios on Aug 8, 2007 3:57:20 GMT -5
Hi guys, This is my 1st time here in the forum. I had some wiring questions to ask all the experts here. I would like to do a mod on my s-s-s strat. I would like to wiring the neck and mid in series and another mod to activate all 3 pickups. I've been trying to search for this wiring diagram in the forum but I cant find any. I have found a schematic from seymour duncan that enable me to activate all 3 pickups. www.seymourduncan.com/support/schematics/switch_f_bp.html but I still cant find the series mod wiring. Will anyone be so kind to post up the wiring diagram? Thanks a lot in advance!!! O ya, I will be using a push/pull switch instead of a toggle switch. Best regards matt
Post by michaelcbell on Aug 8, 2007 5:55:59 GMT -5
I will assume that you are using standard witching currently and don't want to lose any of your current switching capability - you simply want to add the two options you have listed above. If this truly the case, please let us all know so that we might be able to help more accurately.
mattdavios
Post by mattdavios on Aug 8, 2007 14:02:26 GMT -5
Thanks a lot michaelcbell....ya that's what I wanted to do for my strat
Post by sumgai on Aug 8, 2007 20:06:20 GMT -5
matt, Hi, and welcome to the NutzHouse! ;D If you'll accept more than the two additional combinations you listed, you might try this scheme: If you don't want the phase-inverting or the series/parallel switches, you can safely eliminate them. This came from Cheshirecat, who modified an earlier drawing by Mike Richardson. It's been around quite awhile, and is fully tested. And well regarded, too. If you "happen" to have a Deluxe Strat with an S1 setup, this is right up your alley! HTH sumgai
Post by ChrisK on Aug 8, 2007 20:26:38 GMT -5
