avor
Post by avor on Jan 9, 2008 20:04:24 GMT -5
I got all my stuff and redid the wiring in my Strat - it sounds great, btw - but it has static pops now. Took me a while to figure out, but after some trial and error I've found discharching on the strings causes a little pop. It may have always done this (I'm going through under a "new wiring scruteny" phase) and may be completely normal, but I don't remember it happening before. What gives and how can I stop it? Thanks!
Post by ccso8462 on Jan 9, 2008 20:44:27 GMT -5
Hey avor, what mods did you do? Sounds like you may have a grounding problem. I used to get static pops from my fingers & hand brushing the pick guard. A QTB solved the problem. I'd check to see that everything is grounded first, strings, pick guard, etc., then move on to other possibilities.
libirm
Post by libirm on Jan 10, 2008 15:00:16 GMT -5
Avor ~ please post what you find because.. I just did the same thing- changed pots,cap,P/U's I know all my pots are grounded but where else would I look?
libirm
Post by libirm on Jan 10, 2008 15:05:42 GMT -5
Hey avor, what mods did you do? Sounds like you may have a grounding problem. I used to get static pops from my fingers & hand brushing the pick guard. A QTB solved the problem. I'd check to see that everything is grounded first, strings, pick guard, etc., then move on to other possibilities. HTH What s QTB?
Post by ux4484 on Jan 10, 2008 15:22:16 GMT -5
Why it's the reason many of us came to be in this place.
Post by ccso8462 on Jan 10, 2008 16:45:29 GMT -5
Just click on ux's link above and you will enter the glorious realm of Quieting the Beast (QTB). ;D For single-coil users it is indispensible, and even a humbucker-equipped guitar can pop due to static buildup under the pick guard.
libirm
Post by libirm on Jan 10, 2008 17:34:09 GMT -5
Dudes your guys rock!
