robert43
Post by robert43 on Mar 12, 2008 2:59:17 GMT -5
Hi I am thinking of making my Jazz bass in to a blend with series / parallel switch , with 1 volume pot + 1 tone pot. Can any 1 draw out the diagrame ? thanks
Post by ChrisK on Mar 15, 2008 14:40:45 GMT -5
robert43
Post by robert43 on Mar 16, 2008 3:24:00 GMT -5
Eer thanks but I dont understand where it doesnt show the volue & tone where do they go ? thanks
Post by ChrisK on Mar 17, 2008 0:00:10 GMT -5
"Series_Parallel Blend Pot w/ DPDT switch" is a switching/blending module. This connects directly to the pickups. In your instance, "Downwards" goes to signal ground. "Upwards" is the module output which goes to the volume and tone controls, which are between the switching/blending module and the output jack. Your volume and tone wiring would be implemented like this: www.fender.com/support/diagrams/pdf_temp1/basses/0193200_02A/SD0193200_02APg2.pdfThe "black wire from neck pickup" would be the "Downwards" connection and the "white wire from bridge pickup" would be the "Upwards" connection. This is kind of confusing since this bass only has ONE pickup, but it's in two pieces so "bridge" and "neck" does mean which piece. StewMac's Free Guitar Wiring Info Link
Post by ChrisK on Mar 18, 2008 12:46:42 GMT -5
robert43
Post by robert43 on Mar 19, 2008 3:12:02 GMT -5
Thanks for that
