msurdin7
Post by msurdin7 on Apr 12, 2006 15:53:06 GMT -5
Hi i'm new here, and i've heard alot of grea things about this board. Hopefuly i can become a part of the community!
here is my question.
are there any instrustions with pictures for wiring to combine the neck and bridge pickup. But with a little switch. And not use a push pull pot.
thanks
Post by sumgai on Apr 12, 2006 18:56:13 GMT -5
msurdin7, to the forums. Yes, we can always use more contributors here, so jump on in whenever you're ready. You'll need to be a bit more specific about what you're trying to accomplish. F'rinstance, what kind of guitar are you trying to modify? It sounds like you're dealing with a Strat style guitar, but we should be sure of our facts before we take off on this. Also, don't be surprised if a Moderator (I'm not one) moves this thread to the appropriate forum. sumgai
Post by UnklMickey on Apr 13, 2006 11:12:36 GMT -5
hi Msurdin7, John Atchley explains how to do this, pretty well on the Guitarnuts site: you have your choice of doing a neck-on, or bridge-on switch. the drawing he has: shows a DPDT switch. that could either be a push-pull pot or a mini-toggle. let's say it was a mini-toggle. with the wiring shown, the neck pickup would be on whenever the toggle lever was up. if you use a SPDT that will be easy to figure out, since the switch will look like just the left half of the switch in the drawing. if you use a SPST switch, you'll only have 2 terminals. no confusion on which ones to use. only on which way the switch needs to be turned, so that the lever is in the position you want, when the switch is on. unk
