Post by michaelcbell on May 11, 2007 8:21:42 GMT -5
(EDIT: moved to Schematics on May 27th, by sumgai)
About a month ago, I set out on a quest for something intuitive and easy to use, quick switching, yet ultimately flexible in terms of tones and combinations for my Korean Squire SSS Strat, since it was become quickly obvious that my dreams of a new HSH custom guitar were far-fetched at best (at least for a few years). I tried one layout, and posted in the E&W section, but i really was very unhappy with it, so I gave up on that design and tried anew. Whether I fulfilled my goals this time I'll leave up to the whims of the gods, but I'm pretty happy with it (of course, I thought that last time...)
Down to the nitty gritty:
Switches:
SW 1 is a 5-way super switch which gives the following pickup combinations
1 - N & M
2 - Single Coil
3 - N & M & B
4 - N & B
5 - M & B
I have found that I use the NM and MB combinations much more often than the single coil sounds, so I moved those combinations to the ends of the switch to make them easier to find.
SW 2 is a 4PDT which selects whether the combinations given by SW 1 are in series or parallel.
SW 3 is a SP3T that selects which single coil is on when SW 1 is in position 2.
SW 4 phases the neck pickup.
Let's start with a schematic:
I'va also included a little tone variation that was developed by JohnH in E&W, giving variable tone (It will fade from a .022uf sound to a .069uf sound, but how I'm not sure. I'm building it now, and I'll let you know what happens)
This mod is quite similar tonally to JohnH's ToneMonster2, but I wanted to do it with a blade switch (somehow I can't give mine up, plus I play a few songs that demand the quick switch) and I didn't include the blender because I'd end up chopping off a hand...or...something.
Thanks to all who comment, and special thanks to all you out there who have helped with the peices to put this one together. Pictures will be forthcoming.
P.S. I know I've got my cap symbols backwards - sorry about that.
P.P.S I originally posted this in schematics, but decided it might be better to discuss here.
So, it's finally done.
This mod's life in pictures:
Control and pickup cavity before:
and after:
I originally bought some shielding from guitarelectronics.com, but that proved to have non-conductive adhesive, plus there wasn't nearly enough, so I bought a roll from StewMac and basically re-did the job.
back of the pickguard before:
and after:
note that in these pics, the controls are unconnected to the jack.
The controls from the front:
The volume is a p/p for phase, the slider selects the single coil, and the toggle is the series/parallel switch.
Conclusion:
This mod is made me feel quite a bit like I did when I first got my PODxt Pro; it's awesome, but it's sheer versatility is a bit overwhelming at first; I was a little lost. I've played it a couple of days now, and I'm getting used to everything, but my pod took me a month to really become as useful as I'd like, and I can say it's probably the same for this design. Just to clarify, I'm very happy with it.
I'm not as happy with the tone concept, and I'm performing a mod right now to re-vamp it a 'bit', with log pots (at least in this configuration, all my tone play is from 0-4 with a linear pot), and I'm using the extra pole on the super switch to do tone pot selection; the first tone knob will be on in pos 1-4, and the lower tone will be active in pos 5 (my favorite combination in the stock wiring). I'm also re-installing my old .033 cap on the lower tone knob, and adding a SPDT on/off/on to select between .022 and .047 for the upper tone, which also gives me a very nice no-load option. Unfortunately, I busted the on/off/on I had when installing it and got back to Radio Shack ten minutes after closing. Oh well, tomorrow at 10:00am is another day.
Sheilding note:
I LOVED the copper tape I got from stewmac, but I must warn those who use it to be careful while handling: it bites (very much not figuratively, but absolutely literally):
Switches:
1 - N & M
2 - Single Coil
3 - N & M & B
4 - N & B
5 - M & B
and after:
and after:
Conclusion:
Sheilding note:
