hooglebug
Post by hooglebug on Jun 30, 2008 19:44:37 GMT -5
im making a new guitar with 3 burns tri-sonics, master vol + tone (with push/pull to add bridge to any selection), and 5-way switch with usual strat selections.
i was wondering if its possible to add a 3-way tele type switch for series/off/parallel? am i kidding myself? if it is possible, how the hell do i do it?
if its not possible, how/where would i introduce a two way mini toggle for series/parallel?
Post by newey on Jun 30, 2008 22:42:12 GMT -5
Bug- Hello and welcome! Your description says you became a member in "Jul 2008", but it's still June 30th where I sit, so I gather you are located well to the East of me . . . It is possible to do so if you can physically fit that switch and the 5-way into the guitar, along with all the rest of the wiring, pots, etc. There are other schemes which will give you some (but not all) of the series/parallel combos with fewer switches. Similar mods have been discussed before hereabouts. Scroll through this board and you'll find discussion of using Tele type switches for series/parallel. EDIT This was the thread I was thinking of; there are others: guitarnuts2.proboards45.com/index.cgi?board=wiring&action=display&thread=3354
hooglebug
Post by hooglebug on Jul 1, 2008 6:03:36 GMT -5
thanks for the reply!
im making it so i can fit pretty much anything i want in there hehe.
i really like the idea of just having the option of the usual strat selections too tho is the thing. so having the seperate switch is ideal for what i want to do. iv searched and searched all over the place but never seen anything with a lever type switch for series/parallel stuff.
Post by JohnH on Jul 1, 2008 6:43:48 GMT -5
hooglebug
Post by hooglebug on Jul 1, 2008 6:50:31 GMT -5
thanks for that! i shall have a good read through and try and work out something that works for me. it'll give me something to do anyway! hehe
hooglebug
Post by hooglebug on Jul 3, 2008 10:38:22 GMT -5
Post by ashcatlt on Jul 3, 2008 12:57:47 GMT -5
Not that thing again?!? It hurts my head. Maybe this time somebody with a little more patience (and understanding) can sort it out for us.
hooglebug
Post by hooglebug on Jul 3, 2008 13:53:19 GMT -5
haha o dear. hope i didnt cause too much pain
EDIT: ah. o dear. its almost exactly the same thing as the diagram jon h gave earlier only without the series/parallel switch. oops. looks like i shall be trying that one out then
Post by ChrisK on Jul 3, 2008 17:15:46 GMT -5
One thing that might be of importance would be to specify the series combinations desired (which, for three pickups, in total sans phase, are four). Possible Coil CombinationsThere is a Mike Richardson design that gives the following: 1. Bridge 2. Bridge + middle 3. Bridge + neck 4. Middle + neck 5. Neck and 1. Bridge + middle + neck 2. Bridge * middle 3. Bridge * neck 4. Middle * neck 5. Bridge * middle * neck This uses a 4P5T lever Super Switch and a DPDT push pull pot.
