Post by brazilman222 on Aug 12, 2008 16:16:07 GMT -5
Hi i need help with wiring my tele with mini humbucking neck,single coil kinman middle,bridge kinman .I need to get neck and bridge,neck middle,middle and bridge,and if possible all 3 togheter.I have a superswitch 5 2 pole.Fender made.My tech do not know how to do it.Can someone help.No phase reverse or anything like that,no paralel either.Hope i can get it today.Thanks.
Post by ChrisK on Aug 12, 2008 16:31:00 GMT -5
Welcome a'board. To confirm what you are asking for: Pickups; Neck mini-humbucker - is this single conductor with shield? Middle - assumed to be two wire like a Strat pickup with no shield. Bridge - assumed to be two wire like a Strat pickup with no shield. Is the bridge a single coil? You want the following combinations; neck and bridge neck and middle middle and bridge all three together This is only four combinations. You state "no phase reversal or parallel" Do you mean "no parallel" (the way that Strat pickups are normally switched), or "no series"? This is parallel; ____OUT ( ( pickup "A" ( (____GND ____OUT ( ( pickup "B" ( (____GND This is series; ____OUT ( ( pickup "A" ( (__ __| ( ( pickup "B" ( (____GND You indicate a "superswitch 5 2 pole". Superswitches normally are 4 pole 5 throw. Do you really just have a 2 pole 5 throw lever switch? Are you sure that it is not the regular Fender Strat lever switch?
Post by brazilman222 on Aug 12, 2008 22:31:43 GMT -5
Hi Chris thanks for responding.Look I got one mini humbucker and it got wires one black other white.The single coils are kinman boadcaster model for tele.Hum cancelling pickups.I dont know how manny wires they have.I just want to have mini humbucking in the neck alone,neck and middle,middle and bridge,bridge alone,and bridge and neck .I dont know if series or parallel.Please help me.I have the superswitch by fender .I think is the way you said.Its is the one with double 5 way .My guitar is a ASAT classic thinline tele by G&L.Thanks.Sammy
Post by brazilman222 on Aug 12, 2008 22:34:23 GMT -5
Hi chris the superswithc is the samme as the stw mack one.Thanks.
Post by ChrisK on Aug 14, 2008 18:52:36 GMT -5
I asked about series or parallel since IT IS important. If you want switching the same as the G&L does (where pickups are combined in parallel), then this is easy. You NOW state that you want; neck alone neck and middle bridge and neck middle and bridge bridge alone If you are willing to spend about $20 to save about 2 hours wiring time, there is a switch that already does this. It is the Mega Switch "E" from StewMac. These switches, made by Schaller of Germany, have the best mechanical "feel" IMHO.
Post by andy on Aug 14, 2008 20:10:13 GMT -5
If it is any use, the neck and bridge option can easily be gaind at the cost of one of the 'x' and middle options-
Just switching the output leads of either neck or bridge with the middle one will give the neck and bridge option, but lose the mix between middle and whichever pickup wasn't swapped.
That is how I wired my Nashville Tele, and now I have neck, neck-bridge, bridge, bridge-middle and middle.
Thats not exactly what you asked for, but is an extremely easy and cheap option which will get you much of the way there.
Another choice is to add a switch or push-pull pot to add the neck (or bridge instead) to any selection, leaving the five original options, plus bridge-neck and all three. That, and any other switches, however, are for more the knowledgable electricians here to tell you about far better than I could!
