Post by angelodp on Jun 8, 2009 9:34:01 GMT -5
Just read an article that talked about using very small caps for tone adjustment..... 3300pf. The notion being that the lower value will allow more subtle range of control. The standard caps are in the .047uf to .022uf range. I do like a bright and twangy tone. Question is; what have you all found in terms of using smaller cap values.
ange
Post by D2o on Jun 8, 2009 9:43:07 GMT -5
Post by D2o on Jun 8, 2009 11:38:13 GMT -5
Ange, That's a much smaller cap value than I had first realized. Can you give a link to that article? EDIT: I've found one of many example articles, below. In this article, the author discusses capacitance - and how changing it affects tone. True, of course, but there is no mention that pot values matter, too. A 500K pot can certainly brighten things up. D2o
Post by sumgai on Jun 8, 2009 12:12:25 GMT -5
Just read an article that talked about using very small caps for tone adjustment..... 3300pf. The notion being that the lower value will allow more subtle range of control. That'll be subtle, all right. That's 0.0033µf, about a tenth of what you need to get a normal range of variation. The net effect will be that you'll get the same tone no matter where the tone control is set. The capacitance value is so small that very little of the high frequencies will be shunted to ground (signal return). That article's author must have a different idea than mine when it comes to variations in tone. Or perhaps I'd think the same way if I were to smoke some of that stuff he's got in his pipe..... HTH sumgai
Post by sumgai on Jun 8, 2009 12:32:23 GMT -5
I just checked the article linked by D2o above.....
The guy admits to disliking Telecaster Neck pickups (presumably stock ones), and loves twang. This goes a long ways towards explaining his inability to use standard controls (and capacitor values) in a standard way - his ears are definitely out of calibration!
If I were to turn it down from Blood-curdling to merely Ice-pick-in-your-ears, and thought it was a good variation, my frau would be sending me in to have my ears checked!
Post by angelodp on Jun 8, 2009 12:35:14 GMT -5
Ok so .022uf is on the normal bright side of things. I was wondering about those extremely low values.
ange
Post by wolf on Jun 8, 2009 13:09:04 GMT -5
For one thing, shouldn't articles, discussions and rumors about tone capacitors be discussed in nano-farads? Capacitors can get confusing because of the large variation in values. I can remember the days before the pico-farad when capacitors were rated in micro-micro-farads. A 100 picofarad capacitor would have a value of 100 μμf. Anyway, I guess we could say the typical value of a guitar tone capacitor is 22 nano-farads. Here's yet another opinion about the guitar tone capacitor "controversy": Article link: www.electric-guitar-info.com/guitar-capacitors.htmlSo, according to that guy, a tone capacitor should be anywhere between 1 and 10 nano-farads. From the April section of the previous article: www.premierguitar.com/Magazine/Issue/2008/Apr/Auditioning_Tone_Capacitors_Part_II.aspx3.3 to 6.8 nano-farads. So, we can see that is a much more conservative approach than the electric-guitar-info guy.
Post by angelodp on Jun 8, 2009 14:08:17 GMT -5
22 nano-farads. ........ I have a 20 nano-farad cap or .018 uf . I might try that for a slightly brighter cap.
Post by ChrisK on Jun 8, 2009 16:51:16 GMT -5
