Post by resistor on Sept 8, 2009 11:54:58 GMT -5
hay kyle i have three switches a stick of gum a roller skate key and pickups two what should i do
Post by KIIMH on Sept 8, 2009 12:48:41 GMT -5
eezy-peezy, dud. the gum holdz teh two pickups an the wrapper is a conductiv shield. the switches are as follows: one for my split presonalitees ; one for ur split personelities ; one is a phase switch - in cas either of us is going thru a phase. the key terns it on and off, seeing as the on-off switches are otherwsie engaged. Sorry I haven't been able to come a'board lately. It's been a bit busy with - hopefully - no end in sight, so you may not see as much of me as usual on the frontlines. I've been watching though (but you already knew that). klye P.S. By the way, this past September 5 marked 2 years since the unexpected departure of Unk.
