ditch
Play the music, not the instrument.
Post by ditch on Feb 15, 2010 6:18:15 GMT -5
HI, I am, to put it simply, looking to do this:- But to then leave with both hot and not outputs so I can go on to a phase switch etc. How would I do this? Many thanks all! Rich
Post by newey on Feb 15, 2010 6:52:31 GMT -5
If you want to switch the phase of one of the 2 coils shown in the picture, put the phase switch across the coil of the one you want to flip before the selector switch. Usually, however, phasing 2 coils of the same pickup won't result in a usable sound.
You already have "hot" and "not" outputs from the switch, the lower 2 lugs. These can be used for switching "down the line", so to speak, including phasing of this whole pickup.
The lower right-hand lug, as shown on your diagram, does not need to be grounded right there at the switch, it just has to find a ground somewhere along the line. Likewise the shield wire; these are depicted diagramatically as going to ground, but it is understood that that connection may be made elsewhere. In the case of the shield wire, you would want to ground that as far down the chain as you can, to avoid possibly introducing noise into the signal path.
ditch
Post by ditch on Feb 15, 2010 8:10:43 GMT -5
Excellent, thats what I suspected but needed confirmation.
It isn't to phase within one pickup, but to phase this pick up with others, while still having the option of series, parallel, south coil on the humbucker.
Thanks you very much, I'll go off and warm up my soldering iron!
Post by ashcatlt on Feb 15, 2010 12:57:49 GMT -5
I don't know for sure if it was clear from newey's post, but if you're going to do a phase flip, you don't want to be flipping the shield to the hot output, so you will not want it to connect to the "South Start' before reaching this S/P switch.
I guess maybe, it was fairly clear, but I've reiterated...
