Post by famousbirds on Mar 7, 2010 19:51:16 GMT -5
I don't care for the default Gibson wiring (Vol/Tone for each pickup).
I'd love to have something like:
Master Volume Master Blend Neck Tone Bridge Tone
Where the blend knob only affects the middle position on the pickup selector.
I've not seen this wiring before in conjunction with a three-way switch - I've done blend knobs on my basses before with great results.
I've played around trying to figure out a schematic that would work for this, and have not had much luck. I suspect I'll need a three-way switch with more than one pole. Any ideas?
Post by newey on Mar 7, 2010 21:29:02 GMT -5
Famousbirds- Hello and welcome! I also suspect you will need a DPDT On-On-On to have this set up so that the blender only works when the switch is in the center position. But I'll let others take a run at this, if anyone has any creative way to make this happen . . . Actually, you don't really need a pickup selector at all if you have the blend pot- but I understand the desire to retain the switch for a quick change in live playing. I don't know that we have an existing diagram hereabouts, but again, I'll let others weigh in. That is, assuming you're not wedded to the stock switch. EDIT: And, before you run out and buy the blender: ChrisK's "Blend and Pan Pots", from our Reference section.
Post by wolf on Mar 8, 2010 15:07:24 GMT -5
Post by JohnH on Mar 9, 2010 5:38:38 GMT -5
Wolfs diagram, if adapted to an LP type guitar, would have the two halves of the blend pot wired to the two pickups, then the 3 way switch, then master tone and volume. The blend pot that is needed is a dual gang pot, with the two tracks specially designed to go 100%, 100%, 0% on one half, and 0%, 100%, 100% respectively, so at the mid position you get 100% of both pups. It means you alswys get a direct connection to at least one pup, while the other gets faded down. There are issues though. It is effectively adding another pot to load each pickup, hence diminshing treble. Also, as you move away from the centre, I would think the reduced pup will fade away rather quickly. However, it seems to work on basses as you say. If I was doing this, I would use an active stage like this: Active Blenderand an on-on-on switch before it to connect the pickups. John
Post by famousbirds on Mar 9, 2010 18:38:41 GMT -5
This is great guys, thank you.
I'm going to try and work up a schematic, I'll post back when I'm done.
