Post by axekicker on Mar 29, 2010 1:19:17 GMT -5
Hi y'all... I've got a humbucker with two wires coming out of it. Can I split this pickup? Or do I need to add new wires? If so, where do I add them/can I add them? Sorry, I'm really new to the mod world so forgive me if this is a stupid question. Thanks.
Post by gitpiddler on Mar 29, 2010 2:27:24 GMT -5
Welcome kicker. The short answer is you're stuck with two wires unless you just want to do an autopsy to see how it's made.
Post by newey on Mar 29, 2010 7:28:17 GMT -5
Axekicker- Hello and Welcome! Gitpeddler has already given you the short answer. Our member Wolf's website has the long answer: www.1728.com/guitar1a.htmAs Git noted, this involves dismembering your pickup. If it's one of those wax-potted, sealed-under-a-cover types, best to just leave well enough alone. If this is a vintage pickup that has some value, or if it has value to you, then also just leave it alone. But if it's an open-coil type and you're not going to be too put out if you wreck it, you can try Wolf's technique outlined above. You might also consider testing your skills on a cheap HB you don't care about first. The concept is simple- you're just disconnecting 2 wires and connecting separate leads to them. The practicalities are the tough part- you're working with very tiny diameter wires that are fragile and hard to solder. Break one, and you've made a paperweight.
Post by wolf on Mar 29, 2010 13:33:15 GMT -5
Well, I was going to put a link to my website but thanks to newey, it seems I don't have to.
... or a refrigerator magnet.
Post by axekicker on Mar 30, 2010 23:53:06 GMT -5
Thanks guys. I'll give it a shot and keep you posted.
Post by sumgai on Apr 1, 2010 22:09:25 GMT -5
