Buzzing
May 29, 2010 13:13:07 GMT -5
Post by dennyb2009 on May 29, 2010 13:13:07 GMT -5
A friends bass , an Ibanez Sound gear 5 string bass with active electronics , has started buzzing . The problem goes away when he turns down the treble knob . That pot has a circuit board attached to it similar to an Artec or Guitar fetish device . would that pot and device need replacing , or would anyone have an alternate solution ? Thanks Denny
Buzzing
May 29, 2010 17:35:09 GMT -5
Post by JohnH on May 29, 2010 17:35:09 GMT -5
Is it a scratchy kind of buzz rather than a deep 60hz hum? Sounds like some grounding issue somewhere. If the active electronics still work, just with added buzz, then they are likely still OK. Could be a ground wire loose. Is the bridge grounded? you could try clipping a wire from bridge to jack barrel and see if the buzz goes away.
Buzzing
Jun 18, 2010 21:17:03 GMT -5
Post by dennyb2009 on Jun 18, 2010 21:17:03 GMT -5
My friend finally got around to bringing his bass back . Your assumption was correct , it was a grounding issue ! The ground wire had a cold solder joint on the circuit board connection . It was still grounded through contact with the metal shielding plate , just not sufficiently for the treble boost cut circuit to work without buzzing ! Thanks again for your help !
