Post by D2o on Jun 30, 2010 9:21:21 GMT -5
Last night I was playing my strat with the master volume on the amp way down, and the pre and “saturation*” on the amp way up (Peavey term for * post / gain / distortion / whatever you want to call it * on their old SS amps).
I noticed a little bit of hum when I was holding the guitar by the neck, with my whole hand squeezing tightly on the neck and all of the strings (so that all of the strings are muted and fretted multiple times - as each finger was fretting each of six strings at least once).
The guitar is dead quiet and hum free when I play it in non-high-gain settings, and is normally very quiet even in high-gain settings … and, No, I don’t generally play with my hand squeezing the living daylights out of the neck and strings, so I’m not exactly concerned.
But I am curious.
So, if those of you with a strat and a spare moment wouldn’t mind, would you please replicate what I did and let me know if you get any hum?
Depending on your results, I may seek to improve the bridge ground.
Thanks, D2o
Post by chuck on Jun 30, 2010 14:20:20 GMT -5
i guess the bridge ground ( or lack thereof ) could cause a hum like that ... when you make it hum , does touching the bridge cause it to stop ? i would think touching the strings would ground everything , but you never know. ... and keep in mind that i am FAR from an electrical genius i cant get any of my guitars to duplicate your hum ... was it just a bit of string feedback perhaps ?
Post by D2o on Jun 30, 2010 14:33:48 GMT -5
No, it was actually when I touched the strings that the hum appeared.
I should restate that it was only slight hum, and in a rather extreme circumstance at that … but since I noticed it, I thought I’d see if anyone else could duplicate it.
Thanks for checking it out!
D2o
Post by chuck on Jun 30, 2010 14:43:12 GMT -5
was beer involved ?
Post by lpf3 on Jun 30, 2010 15:16:00 GMT -5
D2o- This is from J.A.'s original Guitarnuts article on shielding.... toward the end where it says "My guitar Still Hums"........ My Strat(ish) guitar is fully shielded and almost totally hum free but I get the same problem with high gain. It gets even worse with amp sims (in which case I have to use a noise gate). I seem to remember reading somewhere (probably around here) that your body can act as an antenna, and can contribute to noise when you're touching the strings or other metal parts. In any case I think your using high gain is the culprit. -lpf3
Post by chuck on Jun 30, 2010 15:36:41 GMT -5
ok , i have a question ...
you talk about " using high gain " ...
is there any other way to play ?
;D ahhhh ... the joys of HOT SCREAMING guitar tone ... the screamier the better
Post by D2o on Jun 30, 2010 15:45:48 GMT -5
Thanks, lpf3
I suspect that's all it is. My wife certainly agrees that I'm a big-ol bucket a noise, anyway.
If you find a moment to actually try what I've described I'd still appreciate reading your results.
Chuck ... Hum! ... hum ... not buzz.
ashcatlt put you up to this, didn't he? ;D
D2o
Post by chuck on Jun 30, 2010 16:32:22 GMT -5
noooooo .. i wasnt making a reference to an altered state of mind ... well , not altered by any substances . i am talking thick ,saturated , sizzling , screaming , high gain guitar tone
Post by wolf on Jun 30, 2010 16:37:29 GMT -5
D2o I think I may have the answer (although lpf3 explained it quite well). I'd say it's the amp and not the guitar that's the source of the hum.
I too have a Peavey solid state amp which has a saturation adjustment. The amp is over 20 years old and I noticed as the years rolled by that it had a hum problem that was getting increasingly louder. Eventually, I narrowed it down to the reverb and if I set it to zero, the hum went away. My solution at first was to clean the input and output connections which worked ... for a while. So, to make things easier to clean, I took the reverb out of the bottom of the amp and screwed it onto the side. Luckily, all the connecting cables were long enough so that no rewiring had to be done. Now, if the amp gets a little too much hum, I just connect and reconnect the input and output connections a few times.
Granted this was a problem with reverb whereas your problem is related to distortion (aka saturation). Perhaps, Peavey has a problem with making and keeping contacts clean. I don't know. To me, it seems more than coincidence that we both have Peavey amps with hum problems.
Post by D2o on Jun 30, 2010 22:46:24 GMT -5
Wolf, That is very interesting because I have indeed noticed that the amp itself has a small but definite amount of hum ... even with no guitar plugged into it, even with no patch cord, and even with all volumes set at zero. And, yes, reverb does add to that hum. Notwithstanding, nice amps aren't they? This was different than the usual hum though ... I wasn't even sure what drew my attention to it last night, as it is not uncommon that I will max the pre and saturation from time to time. However, I did try to replicate what I observed last night and could not do so, which - in itself - is probably what drew my attention to it ... i.e. it was the first time I had observed that behavior. I don't know if there was an appliance being used that was throwing things off ... maybe we had lots of CFLs on last night? I don't know, but I could not even reproduce what I described myself. Not without socks and beer, anyway. D2o P.S. In all of writing above, I meant to - but failed to - say thanks for responding. Thanks, wolf.
Post by chuck on Jun 30, 2010 22:49:45 GMT -5
socks and beer .... what more do you need ?
Post by sumgai on Jul 1, 2010 11:46:53 GMT -5
socks and beer .... what more do you need ? The third component - a concrete basement floor to hold the puddle of beer that you're going to stand in, whilst getting that thick, saturated, sizzling, screaming, high gain guitar tone. Although I do predict that there will soon be another kind of sizzling, to be followed shortly thereafter by some differently pitched screaming........
Post by sumgai on Jul 1, 2010 12:00:06 GMT -5
This Marine distinctly detects the odor of*.....RF cables!
And to continue with the plagarism theme.....
Dave is here, and on the other side of the door, I can hear him singing:
"No hum, no buzz, no shock you don't need... Wireless setups are badass indeed!"
Jus' a sec, a pair of tailors in white coats have shown up, and they want to fit me for this snazzy new jacket. Dig these backwards sleeves.......
* Quick, where'd I steal that line from?
Post by D2o on Jul 1, 2010 15:58:51 GMT -5
I dunno ... Dave Rat, perhaps? Anyway, it's Canada Day, so a little fireworks tonight is okay - even if I'm the fireworks. After that you've got my full attention. What cruel fate do you see wolf and I enduring, sensei? By the way, the amp hum is not intrusive or anything (at least with my amp) ... it's just "there". Please Have a listen to something recorded with the guitar and amp in question - as always, I look forward to your input once you escape. Give my best to kyle while you visit the tailor. Thanks, D2o
Post by chuck on Jul 1, 2010 19:07:08 GMT -5
ahhhh ... the concrete floor and bare feet ... i remember it well . dont forget the bass player with the ancient Ampeg SVT , and reaching over to show him the fret he SHOULD be playing on .
touching the bass's strings with your right hand while muting your guitar's strings with your left is a really fun thing to try
Post by lpf3 on Jul 1, 2010 21:05:07 GMT -5
Let me in, man - I think the cops saw me ........ D20- I'm not hearing a problem. My computer monitors are Roland stereo monitors & I listened to your clip very LOUD & all I noticed was that I really like your tone. Is your Bmn setting Bridge in series with middle & neck? If ya ask me that's a nice tone you got there, what is your switching scheme? Special thanks to Sumgai; I haven't thought about that record in years. ;D -lpf3
Post by newey on Jul 1, 2010 21:35:48 GMT -5
I thought the clip sounded fine, too. But then didn't D2o say he couldn't replicate the problem later? First thing that popped into my mind: "Yeah, they're really cool table candles, man . . ."
Post by D2o on Jul 1, 2010 22:12:16 GMT -5
Sorry guys - that was unintentionally misleading on my part. The recording was demonstrating all of the tones available from the current guitar wiring, but I was referring to it to illustrate the level of hum in the amp and the guitar as they normally sound, not with the problem I was describing. In other words, it was just revealing that the normal amp hum is not that bad. Sorry for the miscue, and thanks for taking the time to listen to it. Yeah, that is B*(M+N) ... B in series with (M in parallel with N). It is a lovely tone that was achieved by wiring it up in accordance with JohnH's most excellent Strat Lover's Other Strat (see my post in reply #36 here). Cheers, D2o
Post by wolf on Jul 2, 2010 0:09:35 GMT -5
D2o Yes, the way you describe that hum is exactly the same problem I had with my amp. The hum is really noticeable when you're playing at low levels in a small room. And they are nice amps which last a long time.
Post by sumgai on Jul 2, 2010 23:43:18 GMT -5
Special thanks to Sumgai; I haven't thought about that record in years. ;D Yeah, but I was fairly certain that most of us would get that reference. I was asking about where I copped my first line - that's a little more obtuse. Hint: Neal Stephenson sumgai
