Post by greeneyezzz on Jul 9, 2010 20:47:57 GMT -5
Right... question :
When playing live we always play with clicktrack / backingtrack. Very simple, a stereo track on an I-Pod, Left is the track for drumboy, Right goes to the front PA. Perfect.
Now, since I am the singer / guitarman of the band, a lot of times I find myself in "difficult" positions, for instance : Singing a line while playing a fridliandoodely 37th chord, this while standing on the tip of my right foot toe because I have to see what button I have to push with my left foot that is hovering over the footcontroller to get to the ultrasolodistortiontappingpatch... it's all about balance... point is : I got tired of that...
So...
I made a MIDI track that switches all my FX perfectly in sync with the backing audio. Works like a charm. Only problem is we now have a PC to take on stage and those things are likely to crash on you mid gig.
So is there something like a device out there (preferably rack mount) that can playback audiotrax (let's say 8 is enough) AND that has MIDI channels you can program and send out?
I know the perfect thing for that is called "MAC" but no, that's not an option now $$$
Anyone out here that has some advice?
Post by ashcatlt on Jul 11, 2010 9:11:34 GMT -5
Look on eBay for an Alesis MMT-8. It's an 8 track hardware sequencer with an FSK sync input and an audio click output.
It'll take some messing around to set it up correctly. You should be able to record the FSK sync to an audio track. Put that on one side of the iPod in place of the click track and route it to the sequencer during performance. You'll then send the sequencer's click track to your gorilla. If that click annoys him (and you care) you could do the click in midi and use a hardware sound module (like maybe a cheap used drum machine) for the actual sound. Of course, if you've got a drum machine, you don't need the ape. More drink tickets for you!
OTOH if the backing tracks are midi to begin with, you could do away with the iPod. Use the mmt8 (or similar) and some multi-timbral sound module.
