Post by ijustwannastrat on Sept 30, 2010 12:47:35 GMT -5
I have some GFS pups, and I'm thinking they are very overwound for my tastes. They are singlecoils, so could I just desolder the eye, and take a couple hundred winds off, resolder the end to the eye, and give 'er? These are cheap pups, and I'm just thinking it would be nice to have some mag pups with the graphtech ghost system I'm putting in soon.
Post by newey on Sept 30, 2010 17:49:41 GMT -5
In theory, yes, you could do so, if they aren't epoxied/lacquered/waxed etc. into a solid brick. But in practice, not so easy to do without destroying the thing. It probably would take more than a few tries to get one that still worked after de-wiring. As you say, they're cheap, so if they're not to your liking, stick 'em on Ebay and use the proceeds to buy ones more to your tastes. That's what I'd do, anyway. Otherwise, "cheap" could become "worthless" real quick.
Post by cynical1 on Sept 30, 2010 18:19:07 GMT -5
newey makes a very good point. Couple that with the fact that single coils can have 7500 to 10000 wraps...you may be at it a while...
Generally, but not always, if a pickup has fewer wraps a heavier gauge wire will be employed.
The correct amount of tension needs to be employed based on the gauge of wire. Too much and the wire stretches...
If you know the resistance of the pickup now, which is only a partial non-indicator of sound, the amount you remove will also depend on the gauge of the wire in there now.
If you're not concerned about turning it into a refrigerator magnet then have at it. If you're looking for a particular sound, then, if it were me, I'd dump it and find one you like out of the box.
HTC1
Post by ijustwannastrat on Sept 30, 2010 20:57:15 GMT -5
Thanks for the input. My thought was to have a Mid/Neck combo ( no bridge pup). A couple thousand winds? hmm... How about 48 turns of some 14 AWG? ;D We have tons of spare laying around class. But in all seriousness, I understand the issue with unwinding the pup. I may just have to lower the pups even further in the body, that might help with the color of the tone I get.
Post by newey on Sept 30, 2010 21:28:29 GMT -5
The easiest thing to change, and should be everyone's first impulse. It can make a huge difference.
Post by ijustwannastrat on Sept 30, 2010 22:20:41 GMT -5
The easiest thing to change, and should be everyone's first impulse. It can make a huge difference. SHOULD be, but remember, this IS the nut haus, und Ich bin versucht ein Mitglied gefullt. (how's that, DF? I haven't seen you lately...)
Post by cynical1 on Oct 1, 2010 11:02:01 GMT -5
...this IS the nut haus, und Ich bin versucht ein Mitglied gefullt. ...which brings to mind Schnitt und laufen...
Post by sumgai on Oct 1, 2010 11:05:18 GMT -5
I'm not going there!
(Oder, Ich Geht Nicht Vorbei!)
Post by ijustwannastrat on Oct 3, 2010 0:53:39 GMT -5
I'm sorry, I am unfamiliar with vorbei...
Post by sumgai on Oct 3, 2010 2:51:47 GMT -5
Correctly speaking, it means "don't go over there". Colloquially, it means roughly the same as us saying "don't go there". Thus, "I ain't goin' there!" is an apt statement, being in the current linga franca and all......
Post by newey on Oct 3, 2010 6:39:19 GMT -5
Warum ist es, das wir auf Deutsch sprechen Heute?
Post by ijustwannastrat on Oct 3, 2010 9:53:20 GMT -5
Warum ist wer? Dunkelfalke? Ich keine weiss.
Post by cynical1 on Oct 3, 2010 11:31:08 GMT -5
...mine was pretty simple...Cut and Run....
Post by sumgai on Oct 3, 2010 11:39:42 GMT -5
No, that would be "Ich weiss nicht" - 'I know not'. (Most of the European tongues consider our construction of grammer to be backwards, but we all know who's correct, eh? ) As to why we're changing over from our normal modus operandi, you'd have to speak to wanner about that one - Ich hab keine ahnung! (I have no idea.) sumgai
Post by gumbo on Oct 4, 2010 6:12:38 GMT -5
As a kid, I always thought of my grammer as backwards, but then, she was a lot older than I was...
Post by cynical1 on Oct 4, 2010 6:47:02 GMT -5
As a kid, I always thought of my grammer as backwards, but then, she was a lot older than I was... +1 for making me think about that for a second or two... Now, back in your box... ;D
Post by ijustwannastrat on Oct 4, 2010 12:14:41 GMT -5
As a kid, I always thought of my grammer as backwards, but then, she was a lot older than I was... +1 As for the deutsch sprecht, my german teacher said I would never use my very broken german in casual conversation. While I know that the nuthouse is for serious business only, my accidental spelling of house as haus kicked my ADD into gear.
Post by sumgai on Oct 4, 2010 13:29:47 GMT -5
As for the deutsch sprecht, my german teacher said I would never use my very broken german in casual conversation. While I know that the nuthouse is for serious business only, my accidental spelling of house as haus kicked my ADD into gear. +1 for sending newey skittering off the road sideways! ;D
Post by newey on Oct 4, 2010 17:11:41 GMT -5
Nothing wrong with a bit of fahrvergnügen. ;D ;D ;D
