peterrabbit
My mileage DOES vary
Post by peterrabbit on Dec 3, 2010 20:12:18 GMT -5
Howdy gang! Assembling an axe with 2 humbuckers (EMG passive), coil split to the south bridge coil, Ser/Parallel between pups, and a blend rather than a 3-way toggle. does this look right? If not, why not? Thanks guys and gals. Peter --------- If you lend somebody $20 and you never see them again, it was probably worth it.
Post by ashcatlt on Dec 4, 2010 0:44:24 GMT -5
Looks alright to me. The blend pot will be a second Master Volume in Series mode. You might prefer to remove that extra load from the Series mode, for the same reason we use bigger pots for HBs than for SCs. Can we wire the S/P switch similar to a Series Override to bypass the Blend? Like so: ...errr maybe not. Might be able to figure something, though. Also, it'll want to be a True Blend Pot
peterrabbit
Post by peterrabbit on Dec 5, 2010 19:29:44 GMT -5
Thanks, Ash - I think I'm gonna run with it the way it is, as soon as I hit an 'Authorized Fender Repair' shop.
Thanks again, very much, for your input.
Peter
