Post by rebel082002 on May 9, 2011 18:53:55 GMT -5
Ok I need help with wiring options. Here are the basics: PRS 513 body with 2 hums (4 wires) and a single instead of 5 singles. 1 tone knob, 1 Vol with push/pull, 2 3way switchs. This is what I currently have.
I would like to change 1 3way to a 5way switch and the wiring to produce the following:
5 Way Switch: #1 - H/ #2 - H/S #3 - H/H #4 - H/S/H #5 - S/H
And then for the Push Pull to Take the Bridge Series/Paralell
Now I still have the 3 way.. I am open to opinions here. Maybe Split the neck Hum for more strat tones???
Post by rebel082002 on May 9, 2011 19:39:33 GMT -5
Ok I have confused my self. To simplify things, please just give me my best options for the following set-up. H/S/H with 1 vol and 1 tone knob( One can be Push/ Pull but does not have to be), 2 Blade Switches ( 3 or 5 way). Bridge PU is SD Custom 5 with 4 wires Single PU is Fender Alinco 3 Reverse wound Neck PU is PAF Clone with 4 wires Body is Maple PRS 513 Copy with Rosewood neck. The most important thing is to have a good H/H Les Paul Tone and one good Single Coil Strat tone. Question: Has anyone ever used a Megaswitch E+ - www.eyb-guitars.de/Eyb-English/Megaswitch_files/English%20Megaswitch%20E+.pdfAll opinions welcome.
Post by newey on May 9, 2011 21:27:49 GMT -5
We've had discussion of the Megaswitch E but I don't recall anyone actually using one. Dreamert did provide us with the pinout diagram for the Megaswitch S recently, so if you get an E model and diagram the pinout, we can add it to the collection. As far as an HSH which gets HH and single coil sounds, we had this one a while back, which has a mode switch to go between a 2-HB LP setup and a SC Start set-up with the flick of a switch: HSH switched between SSS and HH
