Post by ashcatlt on Jul 22, 2011 13:04:14 GMT -5
For about 13 years I've been dragging around one of these:
Mine doesn't have the meter bridge, but it's bigger than it looks - about 4 x 3.5 feet – and weighs a ton! It really is a great board with all the pro features. It's a “inline” console with a separate Tape channel for each of the 32 regular channels, so it can act as a full 64 channel board. All kinds of sends and inserts, 8 sub busses. It reads and writes SMPTE timecode and offers mute automation via either snapshots (synced to the SMPTE) or MIDI note on messages. It's even sends MIDI control change messages from 4 of the bus faders. Doesn't respond to them, but it can be used to control other equipment this way.
Back when I was recording to 16 tracks of ADAT and running like 10 different hardware MIDI synth modules this thing was completely indespensible. Combined with a couple patchbays I had all the routing power necessary to make any horrible noises I happened to be shooting for. I've had it in several different studios from Tampa to New Orleans to Superior.
Currently it takes up about half of Sanidar's basement, but since I'm now recording and mixing ITB exclusively, it's become nothing much more than an oversized monitor controller. That and it's getting a bit old. Most of the time we've had it, it's been protected from cigarette smoke, but if I could get in and scrape all the resin out of it, I could probably stay stoned for a couple years. So it's getting a little flaky. I don't think there's anything wrong with it that a bit of contact cleaner wouldn't fix, but since there's about 700,000 pots, jacks, and switches which need cleaned...
It's just got to go.
So I built this:
The smaller box is a +/- 12VDC supply which I built from the General Guitar Gadgets Bipolar Power Supply schematic. Got lucky to find exactly the regulators I needed in a Proverb which I've had around for over 20 years, but have been afraid of since it runs very hot. I also happened to have a 16VAC power transformer in my box of misfit walwarts. Switched the end to a 1/8” TS so I could interface it with a jack I had. The power for the mixer is connected internally, but eventually I'm going to need at least a couple of mic pres, so I went ahead and provided for power to them via the jacks on top. Rather than invest in a 3 or 4 pin connector for this, I decided to just use 2 TS jacks – one for + and ground, and the other for the -.
Originally I was going to build this thing right into a “modular” patchbay that I had laying around. The idea was that I would drill holes through each of the modules to run the Left, Right, and Ground bus wires through. I'd solder a resistor between the tip of one of the jacks and the appropriate bus, with the sleeve soldered directly to the bus. With 20 inputs in a 24 channel patchbay this would have forced me to get the amplifier module into the space of 2 modules, so I could use the last 2 modules for the outputs. That alone would not have been too difficult, but I still would have needed a separate box for the PSU and another for monitor routing/volume control. When I actually opened up the patchbay I found that it was pretty much set up exactly wrong to follow this plan. I could have probably done it, but it would have been a bh and a half!
So I jumped on another plan. I pulled a 6 ft long 8 channel recording snake out of the system and hacked it in half. That's 16. Then I took a stereo pair and hacked it in half, now I've got my 20. (Why 20? I'll explain a little later) In testing, I found that half of the white cable in the snake was flaky, so I replaced it with half of a single cable which had once been part of a stereo pair. Now I had 20 TS plugs on one end and bare wire on the other end. Stripped and twisted all 40 wires (inner conductors and shields) and soldered them to a bus arrangement across the board. From there, the amplifier section is easy – just two of these (the 2K resistor at the front represents one of ten inputs):
The opamp I used is a TL072 and it sounds fine to me, but it's socketed in case I ever decide to go cork sniffing.
The jacks are all stereo jacks, and the pots are dual ganged. The single pot over by itself is the Master Gain. The jack beside it is a passive output. Comes from the node where all the 2K resistors combine, and is there in case some time I want to use something else (a tube preamp or whatever) as a recovery stage. Not that I have any plans for that sort of thing right now, but I like to keep my options open, and for $0.50 and about 30 seconds to drill the hole...
The other four jacks are the active outputs, and each has it's own independent Volume control. In the studio right now I've got two working pair of monitors and a third awaiting a power amp, plus a headphone distribution amp. So I've got independent control of volume for all of these.
I haven't actually gotten the chance to test it since I got all the inputs connected, but I did some tests beforehand by connecting the headphone output from my iphone to the input resistors and the outputs to a small set of computer speakers on my new workbench. It sounds fine to me. With gain all the way down it's basically a unity gain buffer and is flat for as far as the eye can see – like Nebraska! When the gain is way up, theres a bit of rollof at either end of the audio spectrum: -3db at about 20 Hz and about 18KHz. But there's a lot of gain! Somebody told me that each doubling of the inputs will drop the output by 6db once everything is connected. Of course, if two signals are about the same level, mixing them together causes the output to be about 6db up, so that should offset.
Anyway, I don't mind running it at unity. It's got a whole pile of headroom though. 24V peak to peak is enough to crush just about any line-level device. Even with the iPhone and the Gain cranked, I couldn't hear any distortion once I turned the Volume down to a level the poor little amplifier could handle. Not exactly scientific, I guess, but good enough for me.
So how's it going to be used? Well nowadays I'm using a Fostex D2424LV as my “recording interface”. It's connected via lightpipe to my the VSL2020 card in my computer. This only has 2 ADAT I/Os, so I can get up to 16 simultaneous tracks in and/or out at a time, which is more than I've used in years.
So I'll soon have an 8 space rack. 3 for the D2424LV, 3 for my computer, and 2 for patchbays. One patchbay will be for the inputs to the recorder. The other will have the first 16 outputs of the recorder on the top half-normalled to this mixer's “pigtail” on the bottom. The other 4 inputs on the mixer will be for the stereo outputs from my computer and then a spare set for anything else we might want to patch in. The outputs will go to the monitors I discussed earlier and everything will happy. If desired, I could run one of the outputs back inputs on the computer (either via the D2424LV, or the analog ins on the card) to try the whole analog summing thing that everybody seems to think is so cool. I don't really buy the hype, but again I've got the option.
Overall, this was a pretty simple build. A whole lot of soldering connecting that pigtail, but otherwise not a particularly complex circuit.
So I built this:
