megi
Post by megi on Jan 10, 2012 12:36:56 GMT -5
Did you go for those Entwistles in the end Ape? I'd be interested to know what you think if so! (Hi from the other forum BTW! ;D)
ape09090
Post by ape09090 on Jan 15, 2012 18:34:16 GMT -5
They're in the post
megi
Post by megi on Jan 19, 2012 6:03:59 GMT -5
Have you had a chance to look at the HV58's ape? Or even install them? Would be interested to know what your impressions of these pickups are, cheers!
Post by Deleted on Feb 9, 2013 1:19:50 GMT -5
Hello, i was lurking the net for entwistle ASN 57 when i fell on this forum!!! hmmm... looks like smth i know i thought ;D
I was searching for decent noisless for the bridge position in my strat build. Currently i have no-name neck and middle SC (the neck one sounds fantastic compared to the HS-3) and HS-3 in the bridge. I had tried converting HS-3 into traditional SC by deactivating the lower coil, liked the result, but due to hum i reverted it back. The HS-3 sounds ok, especially distorted, but for solos, in a middle-range (blackmore, malmsteen, etc...) low distortion setup, the no-name neck shines in comparison to the HS-3 in the bridge. I am thinking of putting the HS-3 to the neck, where it feels at home, and getting something a little hotter but similar for the bridge. I have read good things about entwistle and this thread by known members here just confirms that. I might give a go to ASN 57 for the bridge. What do you think?
Runewalker and sono, if you remember what was the vertical depth of the pup in comparison to the HS-3?
Thanx!
Post by Runewalker on Feb 9, 2013 13:25:41 GMT -5
Hello, i was lurking the net for entwistle ASN 57 when i fell on this forum!!!....I was searching for decent noisless for the bridge position in my strat build..... I have read good things about entwistle and this thread by known members here just confirms that. I might give a go to ASN 57 for the bridge. What do you think? Runewalker and sono, if you remember what was the vertical depth of the pup in comparison to the HS-3? Thanx! Sono is off on a church thing and he has the ASNs so I need his input on the relative dimensions of the Ents compared to the dimarzios. My memory is that the hs 2 and 3 are a little taller. I actually wrote Entwhistle about ASN-57s because i wanted a version with 4 wires and a ground. It was a while back but I believe that said his design worked off a notion of not having the bottom coil as big as the top coil to balance out humcancelling with retained Single Coil sound and kept the 2 wire config on purpose. Good in theory and the pups are quite, but the humbuckering function still does not make it sound purely like a SC. Pretty good, just not as much sparkle and is a little more midrangy. Still, quite musical.
Post by Deleted on Feb 9, 2013 14:27:00 GMT -5
Runewalker thanx a lot. So where would you recommend the ASN to be placed ? bridge or neck? This particular strat i am talking about has been developed on the basis of early neo-classical, hard-rock, scalloped neck "philosophy".
If Dimarzio rates HS-3 at 93 mvolt, roughly speaking where would the ASN 57 stand?
Post by Runewalker on Feb 10, 2013 0:59:35 GMT -5
Runewalker thanx a lot. So where would you recommend the ASN to be placed ? bridge or neck? This particular strat i am talking about has been developed on the basis of early neo-classical, hard-rock, scalloped neck "philosophy". If Dimarzio rates HS-3 at 93 mvolt, roughly speaking where would the ASN 57 stand? The ASN's are humcancelling versions of the AS-57 single coils, which are more on the vintage end of things. Funny this is discussion coming up because I have some works in progress and pups laying around, including a HS-3 and HS-2 and was mulling over their application. Also coincidental is that I was going to pull the trigger on an EYGuitar order for some other Entwhistles - X3 --- similar to Dimarzios X2N, not a subtle pup. However the EY folks are off until the 15th. Is Feb 1-15 some sort of critical Chinese holiday? I believe I would place the HS-3 in the bridge and the ASNs in the mid/neck positions, unless you plan on splitting the HS-3. If you are going to split then I would put it in the Neck. Did you listen to Son'o's clip of the Entwistle XS 62N in the neck position? www.soundclick.com/player/single_player.cfm?songid=11285267&q=hi&newref=1He laid a sweet little ditty that does a pretty credible job of depicting that pup. the Entwistle XS 62N is a fatter wound Neo magnet version of the AS-57. So it is a more on the midrange/power side of the sound profile. The ASN-57 is somewhere in between the AS-57 and the Entwistle XS 62N in tonal profile, if that helps. You begin to realize how subjective all of these descriptions are --- hint of blackberry, nose of vanilla, oakey but bright with a Franco clay undertone.... arrrgggh we are Oenophiles ... and that whole "weeno" thing just does not sound right.... I am considering this array: HS-3 bridge. ASN-57 mid. HS-2 Neck with split. But I have not finished deciding. many choices compound decision making. RW
Post by Deleted on Feb 10, 2013 1:27:03 GMT -5
Thanx , i listened to the clip, although i cannot turn the volume up right now. Santana kind of sound, i think. My consideration is with the output. If ASN 57 is even slightly more powerful than HS-3 (most SC's are) then maybe i would put HS-3 in the neck. I can get a good tone out of HS-3 in the bridge, but given the same distortion/amp settings, i *always* end up getting a better sound from the no-name (chinese??) neck SC. OTOH, HS-3 in the neck, IIRC sounded good most of the time. So i am searching for an all-arounder in the bridge.
PS I think they have new year in China, i saw on the TV, so maybe because of that.
sonosonny
Post by sonosonny on Feb 11, 2013 13:44:39 GMT -5
GreekDude-
The measurement on the Ent ASN57 is as follows. I measured from the top of the Pup Cover - top coil (closest to the strings) to the very bottom Pup Cover of the 2nd coil (bottom of the ASN57) where it will fit/sit into the cavity. They are in essence two STACKED coils. Results: 2.7 Centimeters 1 1/16 Inches The online Cm to Inch Calculator results in 2.7 Cm = 1.06299 Inches. In both experiences with installing the ASN57's I have had to remove a small amount of body cavity under the pickup to fit it in nicely. Guess it depends on your string height relative to the top of the Pup/PG.
Not sure of the HS3 top to bottom measurement. SOS
Post by Deleted on Feb 12, 2013 0:46:08 GMT -5
SOS, Thanx a lot. Next time i open the cavity i will measure the depth, the overall height of the HS-3 and post them here.
