spower
Post by spower on Jul 27, 2011 7:05:02 GMT -5
I can not get humcanceling with Dimarzio EVO H-Bucker and TX Special middle SC. I switched the red and green wires. Still no noise reduction just a very small amount of diffence on the noisie between the mid pu position and the split coil HB and middle pu position. I have already checked all grounds. What gives? Should I switch the TX special hot and ground wires?
Post by asmith on Jul 27, 2011 7:51:36 GMT -5
Before we all play Diagnosis Murder, let's clear this up. Please copy and paste this post into your reply, and then delete what isn't true.
To clarify:
You have a humbucker in the Bridge position, and a single coil in the Neck position.
If the above is true, then the guitar hums when:
1. You play "coil-cut" HB? 2. You play "full" HB? 3. You play "coil-cut" HB with "middle" Single Coil? 4. You play "full" HB with "middle" Single Coil? 5. You play "middle" Single Coil?
spower
Post by spower on Jul 27, 2011 9:47:26 GMT -5
To clarify:
YES : You have a humbucker in the Bridge position, and a single coil in the Neck position.
I'm leaving the very small possibility open that the middle sc and full HB maybe on but I do not have it wired like that and it does not sound like it is.
Post by asmith on Jul 27, 2011 12:35:14 GMT -5
YES : You have a humbucker in the Bridge position, and a single coil in the Neck position. I meant "a single coil in the Middle position," but you've still grabbed my gist - my fault, thanks for keeping up. And there I was trying to be clever about this. Ok, if they're DiMarzio wiring, then swapping the red and green will only put the pickup out of phase with the other pickups. Here's Wolf's brilliant image explaining wiring colours. I suspect what is happening is that the coil being cut in the humbucker is the one that is reverse-wound from the Middle pickup. It's this reverse-winding that causes the hum-cancelling. It needs to be the other coil that is cut instead, so that the correct coil is being used in relation to the middle pickup. It is more than likely that swapping the wires of your full humbucker is still cutting the same coil. What you need to do is disconnect the black and the white wires of your humbucker. Then rewire the four wires of the humbucker so that: White is the "+" Green and red are soldered together, and Black is the "-" If I'm right in my guess at your problem, that should result in the correct coil being cut, resulting in a hum-cancelling sound. If not, then we'll try something else.
spower
Post by spower on Jul 27, 2011 12:48:41 GMT -5
I will try and let you know. Thanks dude.
Post by ashcatlt on Jul 27, 2011 15:31:24 GMT -5
It needs to be the other coil that is cut instead, so that the correct coil is being used in relation to the middle pickup. It is more than likely that swapping the wires of your full humbucker is still cutting the same coil... Naw, it'll cut the other coil now unless something else was changed. Problem is that the remaining coil is now "wound" the other way, so it can't buck hum. Does it sound noticeably thinner this way then the original? Can you do the screwdriver test? This works, and is probably best practice, but it can be a bit confusing for some. I think it's easier to just shunt toward the "hot" side rather than toward "ground".
spower
Post by spower on Jul 27, 2011 16:05:56 GMT -5
No dice my friend. I even switched the the black and the white wires back and forth. No change. The split bucker and middle together is a little quieter than just the middle by it's self. Only a little. HB only position is working good. I used this diagram. I changed it for Dimarzio wiring of course. And changed it to running all the grounds to one point.Hmm could the star grounding be causing the problem? www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=1hum_2sing_1vol_1tone_5wayThis seems more difficult than it should be.
spower
Post by spower on Jul 27, 2011 16:12:49 GMT -5
Oh also. White to ground sounds better than black to ground. I did green and red togther.
spower
Post by spower on Jul 27, 2011 17:14:51 GMT -5
You know I think the HB is still on with the middle!! How the hell is that happening?
spower
Post by spower on Jul 27, 2011 17:57:31 GMT -5
Found the problem. Out of all the different wiring diagrams for this set up. This is the one that worked. A had to add the jumper in the notes part. www.guitarelectronics.com/product/WDUHSS5L1101Wow I cant believe all the wrong diagrams out there.
Post by newey on Jul 27, 2011 23:21:45 GMT -5
Ashcatlt said:
Which is what you ultimately did, as per the Guitar Electronics alternative diagram.
In any event, problem solved, so it's all good!
Post by asmith on Jul 28, 2011 3:12:13 GMT -5
Naw, it'll cut the other coil now unless something else was changed. D'oh. Ash is right. Glad it's fixed Spower.
spower
Post by spower on Jul 28, 2011 16:09:08 GMT -5
Thanks guys.You led a horse to water.Then the horse drank. BEER!
