Post by godzillamike on Sept 25, 2011 20:15:20 GMT -5
hi all ... i need some help wiring a aftermarket distortion module i ordered online ...
it has a
b+ for the battery in out ground
my current setup is a seymour duncan with a volume knob and a 3 way les paul type switch ...
can someone please tell me what goes where ? ive tried almost everything and im missing something ....
Post by newey on Sept 25, 2011 22:42:28 GMT -5
gzm- Hello and Welcome to G-Nutz2! Did this unit not come with some sort of instructions? How do you have it wired now? Do you know the make/model of this thing? Ordinarily, I would suspect that this unit would get wired to a switch so that it was able to be bypassed for a normal sound. You mentioned a toggle switch on your guitar. What is it doing currently? Also, the usual deal here would be to have a TRS jack replacing the std. output jack on the guitar, so that the battery is disconnected unless a guitar cable is plugged into the jack. This is wired just like a pedal is wired, to save battery life. So, for now, I've got more questions than answers . . .sorry!
