Post by asmith on Oct 25, 2011 8:37:47 GMT -5
In light of Roadtonever's thread, (which quoted this scheme originally by sumgai) on how to achieve the sounds from The Pezzecaster using three poles instead of four, I gave the original Pezzecaster an overhaul. Previously, the Phase Switch of the original scheme did nothing when actuated in the "Bridge only" or "Neck only" positions. We could use the extra pole to get more out of the guitar.
Please can I get other pairs of eyes to take a look, and get a check-over from the board that it does what it ought to.
Click here for a diagram of version 3. This diagram had an intentional "off" spot in Pos. 1, phase switch pulled. Still a viable diagram, although I personally prefer the latest version above.
Click here for a diagram of version 2. This diagram had issues with the "low cut" capacitor affecting position 1.
Click here for an old diagram of version 1. I spotted a mistake in my wiring.
As before, the asterisked Outputs from Position 2 indicate that the Tone Control has been moved from being a "Master" control, to only operating on the "Neck" pickup in a BxN configuration. This allows the "broadbucker" effect.
In positions 5 (Bridge only) and 1 (Neck only), the Phase switch now does different things.
In Pos. 5, pulling the Phase switch now yields a "Half-Out-Of-Phase in Parallel" sound, denoted by the asterisk next to it.(1) The capacitor is in series with the Neck Pickup, in order to achieve the high-end of the bassiest pick-up, and so hopefully the mids overall, being the most "out-of-phase" of the freq. spectrum.
In Pos. 1, pulling the Phase switch also yields a P-HOOP position, denoted by the double asterisk. This time the capacitor is in series with the Bridge pickup. This should only give the top-end of the freq. spectrum the out-of-phase "snap."
Thanks in advance,
A.
1) HOOP in Parallel: as far as I figure, sticking Roady's original module in series with another pickup will cause both pickups to be affected by the cap, weakening the sound even further. Series OOP with a cap in parallel with one of the pickups is already "Position 4, Phase Switch on."
EDIT: Spotted my own mistake in the diagram and fixed it.
EDIT: In previous versions viewable on those small links, I included a tone control which was effectively the Schaller/Framus Tone Circuit with a control pot. However, it messed up Pos. 1, adding in the Neck Pickup as the tone was turned down. Also originally left the HOOP cap's position as optional - but dictatorially, I think it will work better in its current spot.
Thanks in advance,
A.
