krade23
Post by krade23 on Jan 31, 2012 8:05:30 GMT -5
Hi there,
Is it possible to wire a 2 conductor Ibanez humbucker (Red, White, Black (ground i believe) ) into this configuration: Humbucker, 1 volume, on/off mine switch (for singlecoil/humbucker), jack-output?
Is it possible, and if so, how?
Dearest Kristian Strømsholt
Post by ashcatlt on Jan 31, 2012 9:12:17 GMT -5
I count three conductors.
Got a meter?
Post by reTrEaD on Jan 31, 2012 9:36:35 GMT -5
I count three conductors. Got a meter? This. The white is probably hot and the red your series link. But you need to confirm this by measuring the resistance between pairs of wires.
krade23
Post by krade23 on Jan 31, 2012 13:19:44 GMT -5
krade23
Post by krade23 on Jan 31, 2012 13:39:21 GMT -5
I count three conductors. Got a meter? 3 wires? But one of them is a ground?
Post by reTrEaD on Jan 31, 2012 13:47:14 GMT -5
Only a little. If you look at the listing for Ibanez under "2 or 3 wire pickups", you'll see they show the white as hot and the red as "coil tap" (series link). The problem is, not all Ibanez pickups follow the same color code. So if you rely on that (which is the same as I suggested in my previous post) you will probably get it right. Is probably right good enough for you? If it doesn't work properly, will that be because you got the colors wrong or because you made another error. How will you know? I dunno what things are like in Denmark, but in the US, meters are dirt cheap. www.harborfreight.com/merchandising-promotions/merchandising/general-merch-electrical/electrical-testing/7-function-digital-multimeter-90899.htmlA meter is extremely valuable but the monetary cost is extremely low. I don't see how anyone who will be working on guitar wiring would not want to get one.
krade23
Post by krade23 on Jan 31, 2012 16:14:46 GMT -5
Only a little. If you look at the listing for Ibanez under "2 or 3 wire pickups", you'll see they show the white as hot and the red as "coil tap" (series link). The problem is, not all Ibanez pickups follow the same color code. So if you rely on that (which is the same as I suggested in my previous post) you will probably get it right. Is probably right good enough for you? If it doesn't work properly, will that be because you got the colors wrong or because you made another error. How will you know? well, i can always rewire it right? How would i do it, if we just take it plain simple 1 humbucker (2 wire), 1 volume, 1 on/off switch (coil split)? I dunno what things are like in Denmark, but in the US, meters are dirt cheap. www.harborfreight.com/merchandising-promotions/merchandising/general-merch-electrical/electrical-testing/7-function-digital-multimeter-90899.htmlA meter is extremely valuable but the monetary cost is extremely low. I don't see how anyone who will be working on guitar wiring would not want to get one. I will get me one of those as soon as i find one the a local store, cause i checked and they're about the same in Denmark, as in the US - Strømsholt
krade23
Post by krade23 on Jan 31, 2012 16:47:59 GMT -5
Post by thetragichero on Jan 31, 2012 18:43:20 GMT -5
more than likely, you'll only need to use one side of that switch
Post by ashcatlt on Jan 31, 2012 20:36:58 GMT -5
Assuming it's actually a three wire pickup, you'll only need to use two lugs of that switch. Makes one wonder what we might accomplish with the other four...
It's with noting that none of those wires are actually ground or hot or anything else until they're connected to something. Unless the black wire is connected to some metal parts of the pickup for shielding purposes. Then it is probably intended to connect to a "ground" point, but it still ain't ground till it gets to ground.
