Post by angelodp on Nov 26, 2012 11:14:24 GMT -5
Post by newey on Nov 27, 2012 21:04:20 GMT -5
While no HB is dead silent, if you're getting an unacceptable amount of noise, there's a problem somewhere. Durned if I know what to tell you to do, though.
Perhaps try a separate ground wire from the frame of the HB to the back of the pot (in case the shield is bollixed). But, admittedly, that's a shot in the dark at best.
Post by angelodp on Nov 29, 2012 12:17:49 GMT -5
I went to a shielded run which helped, thanks.
