Post by Deleted on Apr 3, 2013 4:01:11 GMT -5
Hi, i just finished with replacing all electronics minus pups in my aria strat (the one with the E-E width nut issue).
It has an original (japanese?) middle pup, for which i dont know the direction of wound with regard to the rest of pups, a dimarzio fast track 1 (mini rails humbucker) in the neck and a dimarzio fast track 2 (also mini rails humbucker measuring about 17KOhm - very powerful) in the bridge. Original i had added the dimarzios with the normal factory strat wiring, just replacing the neck and bridge pickups after putting them in full in-series humbucking wiring. That means i left the original pots, cap and the switch. Now, the pots and the switch were problematic since i bought it in 1984. So i had planned replacing all the pots (with new linear 500Kohm pots), the cap (went for a dimarzio 0.033 uf), the 5-way switch and also giving a go to a push-pull vol 500Kohm audio pot for splitting the bridge pup, and achieving this "quack" in position 2 (middle-bridge).
It sort of went well, but i have some slight issues and observations i would like to share :
- bridge-split-middle position 2 still hums, i am using the "neck"-side coil (rail) of the bridge rails (not the bridge side), so the one closer to the mid pup. Pups are surely in phase, they sound good but hum. Not a big problem, in itself, just an minor issue. Now to solve it i wired the middle pup reversing the polarity, and this solved the noise-hum issue but also brought the two pups out of phase, and the signal was considerably weak. So i guess my only chance here is go and grab one of the remaining original neck/bridge pups of this guitar which i suppose must have been RWRP in relation to the mid pup and try them out.
- the said bridge-split-middle position 2 sounds better, no complaints, but non split it sounds good as well. I was not exactly blown away by the split-mode quack as opposed to full-humbucking-bridge-mid quack i was used to all those years. split mode is better, but non-split worked good as well.
- most important, the 500Kohm linear tone pots, seem to only work in positions 1->3, positions 4->10 just sound the same, with no audible tone change... So i am considering maybe a should go to no-load 250Kohm linear pots? All use the same combinations with audio pots (250/500kohm)? Maybe the 0.033uf dimarzio capacitor has any effect on this? As i understand, the pots (CTS btw, this model EP-4986-000 guitarpartsresource.com/images/large/EP-4986-000.jpg) work quite good, i can do fast wah-wah effects, but still give little space for fine tuning as from 3 to 2 the tone changes dramatically. Will a audio tone pot behave better? i read about it being much worse actually, like ppl with this problem going to audio tone pots only to find that their pots now work from 0->1 only.
