hello I have a simple strat and i want to modified it . for that i have one volume, one normal tone, tone and one tone p/p ,one switch 5 way ,and one 3 way switch toggle. i would like to have selection series and parallèle is that possible and how can i do. thanks
When you say you want a selection of series and parallel, there are 3 pickups. There are 17 possible combinations of three pickups in series or parallel. You certainly can't have all of them with just the switches you have.
You have one P/P pot. This has a DPDT switch, which can be used to switch any one pickup into series or parallel with another pickup. or with whatever is selected on the 5-way switch.
The 3-way toggle may or may not be useful. It depends on what type of switch it is. It needs to be a double pole switch ("DPDT") to be able to switch between series and parallel. If it's like the regular Gibson-style toggles, it won't help with series/parallel switching.
From what you're saying, I would suggest as follows:
Normal Strat volume and 2 tone controls
5-way switch selects the standard Strat selections- N, N+M, M, M+B, B
P/P on one tone pot puts the bridge pickup in series/parallel with whatever is selected on the 5-way switch.
ok newey , thanks effectivly it's gibson toggle 3 way. i will do like you say, even i bought what i need to do some best, i saw few diagram on your very good site...
hi, so i have got few switch on/on and on/off/on i want to explore the possibility for strat sss 5 way switch (in classical wiring) where can i put my switch for parallelle and series.
i have a fender black top wiring (only HH) and i want put series an d parallelle option how can i do.
thanks.
i was looking for wiring diagram i found to much possibilty, so i want to start with my original wiring and just make add.
