giantlaser
Post by giantlaser on Jul 21, 2014 8:02:47 GMT -5
From what I've gathered, I'm having the impression that these will do the trick though? Am I right?
Post by Deleted on Jul 22, 2014 4:08:07 GMT -5
From what I've gathered, I'm having the impression that these will do the trick though? Am I right? I own EMGs but not the solderless version. Most ppl online (for some inexplicable reason to me) claim that the "vintage" soldering way sounds better and has more output.
giantlaser
Post by giantlaser on Jul 22, 2014 7:07:58 GMT -5
Oh that type of guitarpurism again. Myth in reality, crack for marketers.
Will 4-Pin jumper wire fit/work you think?
Post by Deleted on Jul 22, 2014 7:42:19 GMT -5
Post by newey on Jul 22, 2014 7:47:52 GMT -5
Or just solder the dang things on and be done with it.
I guess it's not clear to me what you now have at the ends of the pickup wires. Is there some sort of a plug? The jumper cables you linked to are female-to-female types, I would think you'd need a male plug somewhere along the line.
Post by Deleted on Jul 22, 2014 8:53:29 GMT -5
Or just solder the dang things on and be done with it. I guess it's not clear to me what you now have at the ends of the pickup wires. Is there some sort of a plug? The jumper cables you linked to are female-to-female types, I would think you'd need a male plug somewhere along the line. Hey Newey, both ends of the cables are female. The male plugs are on the pups, switches and pots. But i concur, just solder the sucker, and play problem-free for the next 10 years or so.
giantlaser
Post by giantlaser on Jan 3, 2015 9:22:01 GMT -5
Hi, It's been a while Since I've gotten back to this, sorry if it seems like I'm necroposting. I got me some jumper wire cables and readyness, loose male and female ends like the dupont sort of thing. So yeah that's what I've think I found out, which is if it's a Dupont conector affaire with those EMG's or not.. looks like it is
