dustbunny
Post by dustbunny on Jan 8, 2016 12:00:03 GMT -5
I recently changed out all my PUPs on my Strat to (2) DiMarzio DP110 FS-1's and a Bill Lawrence L500L. Positions 1,3,4,5 sound terrific. Position 2 (mid+bridge) is unusable; it's way over-the-top bright and thin, but doesn't seem to drop in volume so I wouldn't characterize it as weak.
As far as I can tell, the FS-1's are not RWRP and I can't find any info on the L500L.
Is there a solution? Reverse wiring for the humbucker? Thanks for your time.
Post by ashcatlt on Jan 9, 2016 13:30:04 GMT -5
On any guitar I own where the controls are mounted on the pickguard which goes under the strings so you can't get at them and play at the same time, I cut the control section free the first time I open it up. I usually try to line up the cut across two screw holes so I don't need new holes. Anyway.... This will tell you for sure which way each pickup is pushing. One would butt u me that the two from the same manufacturer would be same polarity, so you'll probably just have to swap the other one around.
Post by perfboardpatcher on Jan 16, 2016 3:36:26 GMT -5
I recently changed out all my PUPs on my Strat to (2) DiMarzio DP110 FS-1's and a Bill Lawrence L500L. Positions 1,3,4,5 sound terrific. Position 2 (mid+bridge) is unusable; it's way over-the-top bright and thin, but doesn't seem to drop in volume so I wouldn't characterize it as weak. As far as I can tell, the FS-1's are not RWRP and I can't find any info on the L500L. Is there a solution? Reverse wiring for the humbucker? Thanks for your time. Hi dustbunny, I think you already found the answer. In position 2 you probably have the full humbucker in parallel with the mid pup but out of phase. That would explain the thin sound while still having a good volume. In that case, yes, reverse wiring of the HB. Paul
