slowhand
Post by slowhand on Jul 26, 2016 21:09:12 GMT -5
Hi All,
I have just installed a new pickup set of SH-18 Whole Lotta Humbucker on my epiphone LP.
I have also replaced the entire wiring with the JP modification.
When tried it for the first time, I got a lot of humming that disappears as soon as I touch the strings.
Reading elsewhere I realized that I have a grounding problem. I checked and double-checked the
entire wiring and didn't find any problem (hum still there).
I have checked the ground with a Ohmmeter and the wiring it's OK. (no ground loops).
Next thing, I connected the pickups directly to the guitar output jack only with the pickup selector
connected and the hum is still there! (for each pickup individual and both).
Last, I took the pickups off the guitar and checked the entire ground, and on both pickups I don't get
a continuity between some of the slugs to the shield of the connecting cable (different slugs on each pickup).
Could be this what is causing the problem? Is there a way I can fix it? (I have never took apart a pickup).
Thanks
Post by cynical1 on Jul 26, 2016 21:28:34 GMT -5
Is the bridge ground wire intact and connected?
Happy trails
Cynical One
slowhand
Post by slowhand on Jul 26, 2016 21:44:28 GMT -5
Is the bridge ground wire intact and connected? Happy trails Cynical One Yes
Post by newey on Jul 26, 2016 22:35:51 GMT -5
Is the hum position-dependent as you move about? And, have you tried the guitar with different cables, amp, in a different room, so as to establish that this is really from the guitar?
Have you tried eliminating the switch, wiring each pickup directly to output, individually? What I'm advocating here is a process of elimination, taking each variable out of the picture to ascertain where the problem lies.
Trouble-shooting noise problems over the web is tough, and this sort of "brute force" approach is all I really have to offer.
I'm not familiar with these pickups, but I would think that the shield wire should be continuous only with the cover of the pickup, or with the frame if it's an uncovered one. I wouldn't expect that it would show continuity to the coil slugs.
Post by sumgai on Jul 27, 2016 1:12:24 GMT -5
quicky,
Hi, and welcome to The NutzHouse!
We can't assume that your environment is clean/quiet. Test with another known good guitar that does not hum under most circumstances. If it doesn't hum here, then we're clear to proceed. If it also hums, then before you do anything else, test your guitar in some other location, preferably outside of the building you are occupying. If your axe still hums, and particularly when and where the known good guitar does not hum, then you may need to execute on your warranty.
After all that, please report back with your results. We can go as deep as necessary to fix this, but it won't be a simple one-hour no-brainer, sorry to say.
Patience is the name of the game.
