TV Jones TV Classics, Analysis, Review and Shootout
Oct 22, 2016 21:16:22 GMT -5
davidofchatham likes this
Post by antigua on Oct 22, 2016 21:16:22 GMT -5
www.tvjones.com/tv-classic-pickups.html
Along with the Gretsch Filter'tron and the Fender Filter'tron, the TV Classics are probably the most common Filter'tron/Filter'tron style pickups floating around, so with this set measured, I can now compare all three of them directly.
TV Jones TV Classic Bridge
Series resistance: 4.95k ohms
Series inductance: 2.101H
Gauss: 350 / 350
Unloaded: dV: 1.3dB f: 9.59kHz (black)
Loaded (200k & 470pF): dV: 0.7dB f: 4.36kHz (red)
TV Jones TV Classic Neck
Series resistance: 4.06k ohms
Series inductance: 1.503H
Gauss: 350 / 350
Unloaded: dV: -0.5dB f: 12.3kHz (green)
Loaded (200k & 470pF): dV: 0.1dB f: 5.30kHz (gray)
Bode plot:
Comparisons to common alternatives
The Fender Filter'tron comes stock in Cabronitas and a couple other Fenders that feature Filter'tron style pickups, so a common question is "should I replace them?" and "what to replace them with?" and the answer is usually "Yes", and "TV Classics", so here is a side-by-side of specs
Gauss: 350 / 350
Gauss: 350 / 350
Gretsch Filter'tron Bridge - 006-2876-100
Series resistance: 4.97k ohms
Series inductance: 2.298H
Gauss: 250 / 300
Unloaded: dV: -1.4dB f: 9.81kHz (black)
Loaded (200k & 470pF): dV: -1.7dB f: 4.46kHz (red)
Gretsch Filter'tron Neck - 006-2880-100
Series resistance: 4.18k ohms
Series inductance: 1.7403H
Gauss: 250 / 300
Unloaded: dV: -1.9dB f: 11.2kHz (green)
Loaded (200k & 470pF): dV: -1.9dB f: 5.42kHz (gray)
Fender Fideli'tron Bridge (BHK)
Series resistance: 5.11k ohms
Series inductance: 2.733H
Gauss: 250 / 300
Unloaded: dV: 0.0dB f: 10.6kHz (black)
Loaded (200k & 470pF): dV: -0.7dB f: 3.39kHz (red)
Fender Fideli'tron Neck (BHK)
Series resistance: 4.45k ohms
Series inductance: 2.136H
Gauss: 260 / 310
Unloaded: dV: -1.5dB f: 12.8kHz (green)
Loaded (200k & 470pF): dV: -1.3dB f: 4.73kHz (gray)
Looking at the DC resistance and the inductance together, the most obvious difference between the three is that the Fender Fideli'tron is hotter than either the Filter'tron or TV Classic, which are very close to one another. The Fideli'tron's bridge reads 2.7H to the Filter's 2.3H and the TV's 2.1H, and the Fideli'tron's neck at 2.1H versus the 1.5H for the TV and 1.7 for the Filter'.
The loaded resonant peaks tell the same story, and confirm that all these pickups are very much alike in terms of capacitance effects. The Fender Fideli'tron has a "hotter" bridge/neck loaded peak of 3.4kHz / 4.7kHz, compared to the Filters' 4.7kHz / 5.4kHz, and the TV's 4.4kHz / 5.3kHz. I say "hotter" because these resonant peaks are still plenty bright. A typical PAF has a resonant peak below 3kHz for both the neck and bridge. A Seth Lover set for example, has loaded peaks of 2.5kHz and 2.8kHz.
A financially expedient take away from this is that if you buy a Filter'tron neck and use it as a bridge, you'll more or less have a TV Classic or FIlter'tron bridge.
Bode Plot Comparison
TV Jones TV Classic
Gretsch Filter'tron
Fender Fideli'tron
The most interesting observation here is that the TV Jones TV Classic shows substantially fewer eddy losses than the Fender Fideli'tron or the Gretsch Filter'tron. The Gretsch shows the most eddy losses. If the plot has a steeper downward curve ahead of the resonant peak, it means the eddy losses are greater, and that takes a bite out of the high end response.
There's a lot of anecdotal claims about the TV Classics being "clear" or "articulate" relative to other pickups on the market, and I think that is consistent with what is seen in these plots.
As for the reason the eddy losses are fewer with the TV Classic, I have a bunch of pics below from which you can see how their construction varies, or doesn't. All the pics below are of bridge pickups, which in the case of the Fideli'tron and TV Classics just means there is a spacer bar below the magnet, lowering the base down quite a bit, while the Grestch Filter'tron neck and bridge both have the AlNiCo 5 bar laying directly down upon the metal base plate. That could be the reason, or it might be the screws. I would have suspected the side walls, but as you can see, the Grestch Filter'tron has the shortest side wall of any of them.
Pics:
Shown below are all bridge pickups. I didn't crack open the neck pickups in order the limit the waxy mess. It is also a little more difficult to re-mount these types over overs, you have to manually line them up with the screws and clamp them well. PAF covers are much easier to replace by comparison.
The Fideli'tron and the TV Classic also have wider pole spacing for the bridge pickups, where as the Filter'tron does not, both pickups have the same spacing. In the case of the Fideli'tron, the difference is very slight, perhaps 2mm difference in overall width. The TV Classic is more notciable, with about a 5mm overall difference between the neck and bridge pole piece spacing.
The TV Classic has wood spacers while the Fideli'tron and Filter'tron have plastic spacers. The Fideli'tron and Filter'tron also have rather large, round fillister screw heads, while the TV Classic has more low profile screw heads. The TV Classics have a larger diameter screw also, which probably explains why they show the highest Gauss readings at the screw heads. The TV Classic is also the only set to not have it's screws sticking way out of the bottom of the pickup.
TV Jones TV Classic, Gretsch Filter'tron (recent make), Fender Fideli'tron BHK
Gauss: 350 / 350
Gauss: 350 / 350
Bode plot:
Gauss: 350 / 350
Gauss: 350 / 350
Gauss: 250 / 300
Gauss: 250 / 300
Gauss: 250 / 300
Gauss: 260 / 310
TV Jones TV Classic
Gretsch Filter'tron
Fender Fideli'tron
Pics:
