Post by antigua on Mar 6, 2017 1:08:29 GMT -5
www.seymourduncan.com/pickup/p-rails-set
This set up pickup is essentially a PAF-sized P-90-like pickup with a single rail beside it, all under a one piece plastic cover.
As you can see, I have these pickup mounted in a Seymour Duncan Triple Shot. I kept it wired to the Triple Shot for testing the various modes. Some small portion of the measured capacitance likely owes to the Triple Shot wiring, but these pickups and the Triple Shot ring pretty much go hand in hand anyway.
Electrical measurements:
Seymour Duncan P-Rails Bridge
- P-90 DC Resistance: 10.09K ohms
- P-90 Measured L: 6.250H
- P-90 Calculated C: 229pF (239 - 10)
- P-90 Gauss: 550G
- Rail DC Resistance: 8.48K ohms
- Rail Measured L: 4.517H
- Rail Calculated C: 613pF (623 - 10)
- Rail Gauss: 360G
Without load:
P-90: dV: 7.7dB f: 4.12kHz (black)
Rail: dV: 6.1dB f: 3.00kHz (red)
Series: dV: 6.6dB f: 2.50kHz (green)
Parallel: dV: 6.8dB f: 3.72kHz (gray)
With load (470pF & 200k):
P-90: dV: 3.0dB f: 2.13kHz (black)
Rail: dV: 2.4dB f: 2.06kHz (red)
Series: dV: 1.1dB f: 1.19kHz (green)
Parallel: dV: 3.6dB f: 2.61kHz (gray)
Seymour Duncan P-Rails Neck
- P-90 DC Resistance: 7.19K ohms
- P-90 Measured L: 5.052H
- P-90 Calculated C: 230pF (240 - 10)
- P-90 Gauss: 500G
- Rail DC Resistance: 5.39K ohms
- Rail Measured L: 2.757H
- Rail Calculated C: 518pF (528 - 10)
- Rail Gauss: 360G
Without load:
P-90: dV: 9.3dB f: 4.57kHz (black)
Rail: dV: 4.8dB f: 4.17kHz (red)
Series: dV: 7.2dB f: 3.21kHz (green)
Parallel: dV: 6.3dB f: 4.89kHz (gray)
P-90: dV: 3.3dB f: 2.38kHz (black)
Rail: dV: 2.7dB f: 2.86kHz (red)
Series: dV: 1.5dB f: 1.58kHz (green)
Parallel: dV: 3.8dB f: 3.36kHz (gray)
RLC characteristics...
I just recently evaluated some actual P-90's guitarnuts2.proboards.com/thread/7893/epiphone-90-soapbar-analysis-review . The P-Rails' P-90 coils have a lower inductance that most P-90 measurements I've seen, 6.25 henries in the bridge and 5.1 henries in the bridge. The P-90's I have measured 7.3 henries, and others for which I've seen the values also measure above 7 henries. Tonerider's Vitage 90's show lower inductances of 6.6 and 6.8 henries. The higher the inductance, the lower the resonant peak, the darker the pickup. The loaded peaks of the P-Rails' P-90 is 2.13kHz in the bridge and 2.38khz in the neck, compared to 2.03kHz and 1.92kHz for the real P-90's. The P-Rails' P-90's are therefore a bit darker, and so it appears that P-Rails are wound on the vintage side of vintage, for a P-90. Still nowhere near as bright as Strat, or even most vintage style PAF's, but bright for a P-90.
As for capacitance, the P-90 coils show about 230pF, which is about what I measured in the Epiphone P-90's. The DC resistance is almost similar. I assumed both use 42 AWG wire.
There is a strangely high capacitance in the rail coils, over 600pF in the bridge and 500pF in the neck. It's hard to say why, but it could be the rail itself, the proximity to the larger P-90 coil, or a tight wind with fine gauge wire. It's hard to say what gauge of wire is used, because the coils are so small. I can imagine that in order to get a DC resistance of 8k on that bridge rail, they might have used 44AWG.
All four coils have a clear insulation coat, showing a bright copper color.
Interestingly, the P-90 of the bridge and neck are not all that different in terms of inductance or DC resistance, but the rails coils are very different. The bridge rail has a DC resistance of 8k ohms, and and inductance of 4.5H, while the neck rail has a DC resistance of 5.4k ohms and an inductance of 2.8H. According to the bode plots, the bridge rail and P-90 even have almost identical loaded resonant peaks. The inductance is a lot lower, but that high capacitance brings the resonant frequency way down. To my ear, the bridge rail and P-90 do have a pretty similar treble response, though the voicing is quite a bit different since the two coils sit under different locations along the guitar string. The rail coil is also quite a bit quieter.
A rail also differs from a discrete pole piece in that a pole piece causes induction via perpendicular string movement, where as a rail does not, though this is a very subtle difference. Theoretically, the thinner rail also picks up higher frequencies than a wider screw or slug, but these higher frequencies are likely beyond the range of the guitar speaker's ability to reproduce acoustically. More info about that here www.till.com/articles/PickupResponse/index.html
Magnets...
Regarding magnetic strength, I measured around 500 gauss in the screws of the P-Rails, but barely 200 gauss in the Epiphone P-90s. I suspect that this is due to the P-Rails having AlNiCo 5 bars, while the Epiphone likely uses weaker AlNiCo 2 bars. According to Wikipedia, Gibson switched to AlNiCo 5 bars in 1957 en.wikipedia.org/wiki/P-90 , and according to the Gibson Store, current production P-90's feature AlNiCo 5 bars as well store.gibson.com/p-90-single-coil-with-soapbar-cover/ (On a side note, what the heck does "Output: 9.1" mean?)
The rail shares one of the bar magnets of the P-90. It's sort of a clever arrangement that naturally allows the two coils to mutually humbuck in series or parallel. It's fortunate that the spacing was such that all this could happen with mostly off-the shelf parts.
Counter intuitively, it appears that the rail side actually produces a wider flux dispersion across the string than the screws:
Construction...
The baseplate appears to be nickel silver, and it looks a lot like a PAF base plate with only one side wall. There are two bar magnets and a spacer, similar to a real P-90, though without the slanted angle on the magnets.
The P-90 bobbin is held in with two large brass looking flat heads. There is some wax in there, and what appears to be some glue holding the bobbins together, and the plastic top to the bobbins.
Overall impression...
I definitely prefer the clean tone of these slightly brighter pickups with the AlNiCo 5 bars than the hotter Epiphone P-90 with the apparent AlNiCo 2 bars. The blade and the parallel mode have nice, for Fender-like clean, though with a voicing that is unlike anything you'd hear from a Strat or Tele. For high gain, the series mode really turns this things into fireballs. It's an extremely versatile pickup, mostly excelling in clean tones.
The P-90 coils really are P-90 like, that's no joke. They compare closely to my Epiphone P-90s in terms of inductance, capacitance and resistance.
I'm not crazy about the looks. I wish they had painted the rail cream colored for the cream tops, in order to hide the rail a bit. A P-90 is possibly the most vintage of all pickups, best it stay looking vintage, IMO. They say rails have scared away a lot of guitarists due to their looks alone.
Pics:
- P-90 Gauss: 550G
- Rail Gauss: 360G
Without load:
- P-90 Gauss: 500G
- Rail Gauss: 360G
Without load:
Magnets...
Construction...
Pics:
