swingarm
Post by swingarm on Oct 2, 2017 8:08:42 GMT -5
I have a gibson 57 classic plus pick up that im not going to fiddle with in terms of coil splitting in the bridge position so its two leads. However, I saw this Bill Lawrence q filter and thought it might be fun to try for the bridge. I have not made a selection for the neck yet but like the idea behind the lindy unbucker. I was thinking it might be a good fit in the neck, Any thoughts? I have used the original HBD mod layout and hope i can use 1/2 of it for the neck pickup.I started the layout for the bridge that will use a push pull pot and a regular pot. Maybe one of you guys could have a look and fill in the blanks for the rest of the wiring using ms paint? If so id sure appreciate it hope this link works. Thanks ibb.co/hQFTWG
swingarm
Post by swingarm on Oct 4, 2017 4:14:14 GMT -5
I'll maybe try to get this solved on my own thanks
Post by newey on Oct 4, 2017 20:30:08 GMT -5
swingarm-
Sorry no one got back with you quicker on this. From your description, it's not at all clear to me what the P/P pot for the bridge will be doing- is it an in/out for the Q-filter?
Also:
The key question: Is this pickup the "vintage" style with the braided wire "ground" and a single inner insulated conductor? If so, your wiring options will be even more limited than simply the question of coil splitting (or not).
swingarm
Post by swingarm on Oct 5, 2017 0:27:59 GMT -5
Hey dont be sorry I'm lazy lol, I dont blame people for not answering! I have a 57 classic plus in the bridge that is two wire is as you mention. I guess i will just wire it up simply and just use the neck for coil splitting. Thanks for your reply,
