Post by wolf on Nov 15, 2019 16:52:11 GMT -5
Well, I guess it has been a little while since I last posted here. I wrote yet another web page and this one concerns coil cut by grounding out a humbucker's center wire through a resistor. Here's the link: www.1728.org/guitar15.htm Anyone agree / disagree? (Notice that the web page already says that the folks here at GuitarNutz 2 have helped me with this circuit. So, feel free to just ignore this posting and I promise I will not remove the GuitarNutz 2 praise.) LOL
Anyway, hello again folks!!!
Post by JohnH on Nov 15, 2019 21:07:02 GMT -5
Hi Wolf, it's great to see you again!
Yes I think its a good idea too
It keeps a bit of extra thickness in the tone of a split Hb. Another one I like is to use a cap across one coil instead, such as 47 to 82 nF
Post by wolf on Nov 16, 2019 2:24:21 GMT -5
Hi John, Thanks for the quick reply. I added your suggestion to the "Coil Cut Through Resistor" page. Coil Cut Through Resistor Since your suggestion uses a capacitor, wouldn't that produce more of a tone change than just the resistor? A capacitor would pass more high frequencies to ground than a resistor and might not sound as bright as a regular coil cut?
Post by JohnH on Nov 16, 2019 4:03:08 GMT -5
The capacitor bypass is actualy clearer and brighter than the resistor bypass. At high frequencies, the cap has a low impedance so it provides a direct path for the highs from the non-bypassed coil. At low frequencies, the cap has high imoedance, giving lows from both coils. The result is singls-coil highs and humbucker lows. In between, there are some interesting mid-frequency interactions.
It's my favorite way to split my bridge pick up
Post by reTrEaD on Nov 16, 2019 10:02:51 GMT -5
And it goes without saying that you could use a SPST on-off-on switch to have two flavors of coil cut available in addition to the full HB.
You might choose any two from: Fully cut (short), Capacitor, or Resistor.
And you could use a DPDT on-on-on if you wanted to have the full HB in a switch position other than center.
Post by wolf on Nov 17, 2019 17:03:37 GMT -5
