Post by ourclarioncall on Dec 3, 2019 19:32:36 GMT -5
Wondering what people’s thoughts are on the course content below. I found a series of videos on YouTube. My long term goals would be to be able to modify and build guitars , guitar amps and effects pedal . I am in the UK. University education is not an option so I have to self study and trawl the internet.
Anyway,
Would the following curriculum get me in the ball park of meeting my goals?
Thanks for the feedback
Engineering Circuit Analysis: Volume 1 -- 10 Hour Course
1: Voltage, Current, and Resistance
2: Overview of Circuit Components
3: Ohm's Law
4: Power Calculations in Circuits
5: Kirchhoff's Current Law
6: Kirchhoff's Voltage Law
7: Circuit Analysis using Kirchhoff's Laws - Part 1
8: Circuit Analysis using Kirchhoff's Laws - Part 2
9: Circuit Analysis using Kirchhoff's Laws - Part 3
10: Circuit Analysis using Kirchhoff's Laws - Part 4
11: Circuit Analysis using Kirchhoff's Laws - Part 5
12: Circuit Analysis using Kirchhoff's Laws - Part 6
13: Circuit Analysis using Kirchhoff's Laws - Part 7
14: Dependent Current Sources - Part 1
15: Dependent Current Sources - Part 2
16: Resistors in Series and Parallel - Part 1
17: Resistors in Series and Parallel - Part 2
18: Voltage Divider Circuits - Part 1
19: Voltage Divider Circuits - Part 2
20: Current Divider Circuits
Engineering Circuit Analysis: Vol 2 -- 9 Hour Course
Node Voltage and Mesh Current Analysis Methods
1: Introduction to the Node Voltage Method
2: Node Voltage Problems - Part 1
3: Node Voltage Problems - Part 2
4: Node Voltage Problems - Part 3
5: Node Voltage Problems - Part 4
6: Node Voltage Problems - Part 5
7: Node Voltage with Dependent Sources - Part 1
8: Node Voltage with Dependent Sources - Part 2
9: Node Voltage with Dependent Sources - Part 3
10: Introduction to the Mesh Current Method
11: Mesh Current Problems - Part 1
12: Mesh Current Problems - Part 2
13: Mesh Current Problems - Part 3
14: Mesh Current Problems - Part 4
15: Mesh Currents with Dependent Sources - Part 1
16: Mesh Currents with Dependent Sources - Part 2
17: Mesh Currents with Dependent Sources - Part 3
18: Mesh Currents with Dependent Sources - Part 4
Engineering Circuit Analysis: Vol 3 -- 7 Hour Course
Thevenin / Norton Equivalent Circuits & More
1: Source Transformations - Part 1
2: Source Transformations - Part 2
3: Source Transformations - Part 3
4: Source Transformations - Part 4
5: Thevenin Equivalent Circuits - Part 1
6: Thevenin Equivalent Circuits - Part 2
7: Thevenin Equivalent Circuits - Part 3
8: Thevenin Equivalent Circuits - Part 4
9: Thevenin Equivalents with Depdendent Sources - Part 1
10: Thevenin Equivalents with Dependent Sources - Part 2
11: Thevenin Equivalents with Dependent Sources - Part 3
12: Norton Equivalent Circuits - Part 1
13: Norton Equivalent Circuits - Part 2
14: Norton Equivalent Circuits - Part 3
15: Maximum Power Transfer - Part 1
16: Maximum Power Transfer - Part 2
17: Maximum Power Transfer - Part 3
18: Superposition in Circuits - Part 1
19: Superposition in Circuits - Part 2
Engineering Circuit Analysis: Vol 4 -- 6 Hr Course
Capacitors, Inductors & More!
1: Voltage Across an Inductor - Part 1
2: Voltage Across an Inductor - Part 2
3: Current Through an Inductor - Part 1
4: Current Through an Inductor - Part 2
5: Power and Energy in an Inductor, Part 1
6: Power and Energy in an Inductor, Part 2
7 Power and Energy in an Inductor - Part 3
8: Current Through a Capacitor
9: Voltage, Power, and Energy Storage in a Capacitor
10: Capacitor Problems - Part 1
11: Capacitor Problems - Part 2
12: Inductors and Capacitors in Series and Parallel
13: Series and Parallel Circuits - Part 1
14: Series and Parallel Circuits - Part 1
15: Series and Parallel Circuits - Part 3
16: Series and Parallel Circuits - Part 4
17: Series and Parallel Circuits - Part 5
Engineering Circuit Analysis: Vol 5 -- 5 Hour Course
Natural and Step Response of Circuits
1: Introduction to Natural and Step Response
2: Natural Response of LR Circuits
3: Time Constant of LR Circuits
4: LR Natural Response Circuit Problems, Part 1
5: LR Natural Response Circuit Problems, Part 2
6: LR Natural Response Circuit Problems, Part 3
7: Natural Response of RC Circuits
8: RC Natural Response Circuit Problems, Part 1
9: RC Natural Response Circuit Problems, Part 2
10: Step Response of LR Circuits
11: LR Step Response Circuit Problem
12: Step Response of RC Circuits
13: RC Step Response Circuit Problem
14: General Solution of Step and Natural Response
15: Use General Form to Solve Problems
Engineering Circuit Analysis: Volume 6 --
Op-Amp Circuits, Part 1
1: What is an Operational Amplifer (Op-Amp)?
Sect 2: Op-amp Terminals and Circuit Symbol
Sect 3: Op-Amp Terminal Voltages and Currents
Sect 4: Op-Amp Gain and Linear Region
Sect 5: Ideal Op-Amp Virtual Short and Input Current
Sect 6: Op-Amp Input and Output Resistance
Sect 7: Basic Op-Amp Problems, Part 1
Sect 8: Basic Op-Amp Problems, Part 2
Sect 9: Basic Op-Amp Problems, Part 3
Sect 10: Basic Op-Amp Problems, Part 4
Sect 11: Basic Op-Amp Problems, Part 5
Sect 12: Basic Op-Amp Problems, Part 6
Sect 13: Basic Op-Amp Problems, Part 7
Sect 14: The Inverting Op-Amp Circuit
Sect 15: Inverting Op-Amp Problems, Part 1
Sect 16: Inverting Op-Amp Problems, Part 2
Sect 17: Inverting Op-Amp Problems, Part 3
Sect 18: Inverting Op-Amp Problems, Part 4
Sect 19: The Summing Amplifier Circuit
Sect 20: Summing Amplifier Problems, Part 1
Sect 21: Summing Amplifier Problems, Part 2
Sect 22: Summing Amplifier Problems, Part 3
Engineering Circuit Analysis: Volume 7 --
Op-Amp Circuits, Part 2
Sect 1: The Non-Inverting Amplifier Circuit
Sect 2: Non-Inverting Amplifier Problems, Part 1
Sect 3: Non-Inverting Amplifier Problems, Part 2
Sect 4: Non-Inverting Amplifier Problems, Part 3
Sect 5: Non-Inverting Amplifier Problems, Part 4
Sect 6: The Difference Amplifier Circuit
Sect 7: Difference Amplifier Problems, Part 1
Sect 8: Difference Amplifier Problems, Part 2
Sect 9: Difference Amplifier Problems, Part 3
Sect 10: Common Mode Rejection Ratio Overview
Sect 11: Common Mode and Differential Mode Signal Components
Sect 12: Deriving the Common Mode Rejection Ratio
Sect 13: Common Mode Rejection Ratio Problems, Part 1
Sect 14: Common Mode Rejection Ratio Problems, Part 2
Sect 15: The Integrating Amplifier Circuit
Sect 16: Integrating Amplifier with a Square Pulse Input
Sect 17: Integrating Amplifier Problems, Part 1
Sect 18: Integrating Amplifier Problems, Part 2
Sect 19: Integrating Amplifier Problems, Part 3
Sect 20: Integrating Amplifier Problems, Part 4
AC Circuit Analysis Tutor - Vol 1
Phasor Analysis of AC Circuits
Sect 1: What is Alternating Current?
Sect 2: Sinusoidal Sources, Part 1
Sect 3: Sinusoidal Sources, Part 2
Sect 4: RMS Value of a Periodic Function
Sect 5: Practice with Sinusoidal Sources
Sect 6: Review of Complex Numbers
Sect 7: Circuits with Sinusoidal Sources
Sect 8: The Phasor
Sect 9: Practice with Phasors
Sect 10: Impedance of Inductors and Resistors
Sect 11: Impedance of Capacitors
Sect 12: Practice with Impedance
Sect 13: Kirchhoff's Laws in the Phasor Domain, Part 1
Sect 14: Kirchhoff's Laws in the Phasor Domain, Part 2
Sect 15: Series and Parallel Circuits in the Phasor Domain
Sect 16: Solving AC Circuits with Phasors, Part 1
Sect 17: Solving AC Circuits with Phasors, Part 2
Sect 18: Solving AC Circuits with Phasors, Part 3
Sect 19: Solving AC Circuits with Phasors, Part 4
Sect 20: Solving AC Circuits with Phasors, Part 5
Sect 21: Solving AC Circuits with Phasors, Part 6
AC Circuit Analysis Tutor - Vol 2
AC Node Voltage & AC Mesh Currents
- 6 Hour Duration
Sect 1: AC Source Transformations
Sect 2: AC Thevenin Equivalent Circuit Problems, Part 1
Sect 3: AC Thevenin Equivalent Circuit Problems, Part 2
Sect 4: AC Thevenin Equivalent Circuit Problems, Part 3
Sect 5: AC Thevenin Equivalent Circuit Problems, Part 4
Sect 6: AC Thevenin Equivalent Circuit Problems, Part 5
Sect 7: AC Node Voltage Problems, Part 1
Sect 8: AC Node Voltage Problems, Part 2
Sect 9: AC Node Voltage Problems, Part 3
Sect 10: AC Node Voltage Problems, Part 4
Sect 11: AC Node Voltage Problems, Part 5
Sect 12: AC Mesh Current Problems, Part 1
Sect 13: AC Mesh Current Problems, Part 2
Sect 14: AC Mesh Current Problems, Part 3
Sect 15: AC Mesh Current Problems, Part 4
Sect 16: AC Mesh Current Problems, Part 5
AC Circuit Analysis Tutor - Vol 3
AC Real and Reactive Power Calculations
- 7 Hour Duration
Sect 1: Instantaneous Power
Sect 2: Average Power Definition
Sect 3: Real Power
Sect 4: Reactive Power with Inductive Load
Sect 5: Reactive Power with Capacitive Load
Sect 6: Real and Reactive Power Together
Sect 7: Units of Real and Reactive Power
Sect 8: Power Factor and Reactive Factor
Sect 9: Real and Reactive Power Problems, Part 1
Sect 10: Real and Reactive Power Problems, Part 2
Sect 11: RMS Value in Power Calculations
Sect 12: Complex Power Theory, Part 1
Sect 13: Complex Power Theory, Part 2
Sect 14: Complex Power Theory, Part 3
Sect 15: Complex Power Problems, Part 1
Sect 16: Complex Power Problems, Part 2
Sect 17: Complex Power Problems, Part 3
Sect 18: Complex Power Problems, Part 4
Sect 19: Complex Power Problems, Part 5
Sect 20: Complex Power Problems, Part 6
Sect 21: Maximum Power Transfer, Part 1
Sect 22: Maximum Power Transfer, Part 2
Sect 23: Maximum Power Transfer, Part 3
AC Circuit Analysis Tutor - Vol 4
- AC 3-Phase Analysis, Part 1 - 10 Hour Duration
Sect 1: What is 3-Phase Electricity?
Sect 2: Why is 3-Phase Power Useful?
Sect 3: Balanced 3-Phase Voltages and Phase Sequence, Part 1
Sect 4: Balanced 3-Phase Voltages and Phase Sequence, Part 2
Sect 5: Three Phase Voltage Sources - Wye and Delta
Sect 6: Balanced Wye-Wye Analysis - The Neutral Voltage
Sect 7: Line Currents in the Wye-Wye Circuit
Sect 8: The Single Phase Equivalent Circuit
Sect 9: Line-to-Neutral and Line-to-Line Voltage, Part 1
Sect 10: Line-to-Neutral and Line-to-Line Voltage, Part 2
Sect 11: Line-to-Neutral and Line-to-Line Voltage, Part 3
Sect 12: Convert Between Line-to-Neutral and Line-to-Line Voltage, Part 1
Sect 13: Convert Between Line-to-Neutral and Line-to-Line Voltage, Part 2
Sect 14: Important 3-Phase Circuit Terminology
Sect 15: Wye-Wye 3-Phase Circuit Problems, Part 1
Sect 16: Wye-Wye 3-Phase Circuit Problems, Part 2
Sect 17: Wye-Wye 3-Phase Circuit Problems, Part 3
Sect 18: Wye-Wye 3-Phase Circuit Problems, Part 4
Sect 19: Wye-Wye 3-Phase Circuit Problems, Part 5
Sect 20: Wye-Wye 3-Phase Circuit Problems, Part 6
Sect 21: Wye-Wye 3-Phase Circuit Problems, Part 7
Sect 22: Wye-Wye 3-Phase Circuit Problems, Part 8
Sect 23: Wye-Wye 3-Phase Circuit Problems, Part 9
AC Circuit Analysis Tutor - Vol 5
- AC 3-Phase Analysis, Part 2 - 7 Hour Duration
Sect 1: Delta Load Line-Current to Phase-Current Conversion
Sect 2: Summary of Voltage and Current Shifting
Sect 3: Analyzing the Wye-Delta Circuit
Sect 4: Wye-Delta Single Phase Equivalent Circuits
Sect 5: Wye-Delta 3-Phase Circuit Problems, Part 1
Sect 6: Wye-Delta 3-Phase Circuit Problems, Part 2
Sect 7: Wye-Delta 3-Phase Circuit Problems, Part 3
Sect 8: Wye-Delta 3-Phase Circuit Problems, Part 4
Sect 9: Wye-Delta 3-Phase Circuit Problems, Part 5
Sect 10: Wye-Delta 3-Phase Circuit Problems, Part 6
Sect 11: Wye-Delta 3-Phase Circuit Problems, Part 7
Sect 12: Delta-Wye and Delta-Delta 3-Phase Circuit Analysis
Sect 13: Delta-Wye 3-Phase Circuit Problems, Part 1
Sect 14: Delta-Wye 3-Phase Circuit Problems, Part 2
Sect 15: Delta-Wye 3-Phase Circuit Problems, Part 3
AC Circuit Analysis Tutor - Vol 6
- AC 3-Phase Analysis, Part 3 - 6 Hour Duration
Sect 1: Delta-Delta 3-Phase Circuit Problems, Part 1
Sect 2: Delta-Delta 3-Phase Circuit Problems, Part 2
Sect 3: Review of Real and Reactive Power
Sect 4: Real Power in a Balanced Wye Load
Sect 5: Complex Power in a Balanced Wye Load
Sect 6: Real and Reactive Power in a Balanced Delta Load
Sect 7: Three Phase Power Problems, Part 1
Sect 8: Three Phase Power Problems, Part 2
Sect 9: Three Phase Power Problems, Part 3
Sect 10: Three Phase Power Problems, Part 4
Sect 11: Three Phase Power Problems, Part 5
Sect 12: Three Phase Power Problems, Part 6
Anyway,
3: Ohm's Law
Sect 8: The Phasor
- 6 Hour Duration
- 7 Hour Duration
Sect 3: Real Power
