Post by pablogilberto on Jan 4, 2020 6:56:23 GMT -5
Hello! I have this stock SSS pickups on my vintage strat and I really love them. I'm thinking of building another pickup with the closest specs possible so I can install it with my other strat. I have measure the RLC values using DER EE DE-5000 LCR Meter. I got the following values: Neck DCR - 5.945k ohms Neck Ls - 2.414H Neck Cp - 116.31pF Mid DCR - 5.948k ohms Mid Ls - 2.400H Mid Cp - 118.23pF Bridge DCR - 5.983k ohms Bridge Ls - 2.465H Bridge Cp - 110.86pF Basically, it looks like they have same winding and specs. Here's the photo of the pickup: Here are my questions: 1. Do you have an idea what type of wire is this? For reference, the spool on the left side (reddish) is a Schatten Poly Nylon which I got from Stewmac. The spool on the right is a Polyurethane Enameled Wire from Aliexpress. 2. What's the best strategy to wind a pickup with the closest possible specs? Do I need to give more priority in achieving the same Ls Inductance? Any thoughts and suggestions? Thank you!
Post by ziggystardust723 on Jan 17, 2021 22:21:56 GMT -5
Hello, I'm very surprised than nobody answer to you.. So many times from your Ask.. Sorry: I'm New on this Forum. (& a French guy, so please don't worry to my language.. I'm 66yo, so I left School since 48years, where I learnt English, & in France: we speak only French..) - I wind Pickups for 8years, on a Schatten machine (Canada), - & use 7 differents wires, > but these you Show are the baddest of The 3 kinds, or you Play only Blues: cause this kind of Coat: = the Thinner (near 0,003 mm), > give 'Hot Sound': for Blues.. - for Rock (like J.Hendrix, R.Gallagher etc), the Coat is Brown: = Plain-Enamel wire, - & for 'Vintage+ Sound', like 'The Shadows' (+Jazz, Country etc), > the Coat is Red: Heavy-Formvar wire - The Wire inside is made of Copper, > & you find 3 diff kind of Coat Around it: for 3 diff Caracters of Sounds.. > The 2 Bobbins of Wire you show: = are Near the Same.. > I don't see Heavy-Formvar Coat > or Plain-Enamel brown Coat.. - & you tell to wind pickups, > but How.? - Thince all the Time, I think you done them, but are you really satisfied with the Sound.? - Bye,Ziggy Stardust (France).
