Post by hembryguitars on Mar 30, 2006 21:38:29 GMT -5
It seems simple enough, but I must be to dense to figure this out. I'm trying to get the outer coils when pulling the switch, but I keep getting nothing out of the neck pickup. The pickups and switch are fine. I've tried wiring it a couple of different ways, but still nothing from the neck. It must keep getting grounded out.
Here's the parts: 2 humbuckers 2 volume pots 1 3-way switch 1 shared tone push/pull pot
I've been bulding for a while, but the electronics just stump me sometimes. If you could make a diagram, I would be so grateful! Thanks guys!
Post by dumenegozzo on Mar 30, 2006 22:57:29 GMT -5
I don't get it... If you've done it with the bridge humbucker, how come you can't with the neck pickup? If you post your wiring, I think it would be easier for us do help. Anyway, don't bother, electronics sometimes are quite tricky... EDIT: Are both pickups from the same manufacturer? If not, check again the wires' colors, also test (with a multimeter) if possible. You may have got the wrong wires (but I can't think of any wire exchange that would ground the pickup) or a dead pickup.
Post by hembryguitars on Mar 30, 2006 23:16:16 GMT -5
Same manufacturer. Tested them both, both work fine.
Post by hembryguitars on Mar 31, 2006 1:36:47 GMT -5
I figured it out! I'm not sure what it was. Maybe a bad solder connection. After the 3rd time of unsoldering everything and putting it back together, everything is working fine. Who knows.
Post by dumenegozzo on Apr 1, 2006 4:20:37 GMT -5
It happens quite often. Just check for bad wires or the problem may be back later.
