monradon
Post by monradon on Apr 16, 2006 13:45:22 GMT -5
I am building a Eric Clapton style guitar with gold lace sensor pickups, putting in a hardtail strat bridge he blocks his anyway. I need help on the TBX circuit is there two styles one powered and one not and how would you put in a battery box so you do not need to remove the pickguard everytime what is the best shematic you know with this ??
Thanks
Post by flateric on Apr 18, 2006 13:17:58 GMT -5
The EC Strat has a mid-tone boost circuit that is basically a powered pre-amp. A TBX control is passive, not powered; it is 2 concentric pots linked with a cap and resistor that basically cuts trebles (=more bassy) in one direction and cuts bass (=makes it more trebly) in the other direction. I like them, I fitterd one to my MIM tele recently. For a battery compartment, the guitar body is normally routed out from the rear then a small rectangle of pickguard-like material screwed over the hole once the battery is in. If you search the Fender website, they will give a schematic for the Clapton strat, or go to Guitar Electronics dot com where they sell an EC mid-tone boost pack.
Post by sumgai on Apr 18, 2006 20:50:19 GMT -5
eric, If one can shop from American parts houses, Mouser has this to offer: Mouser Battery HolderOther parts houses might call it a 'battery receptacle', but the idea is the same. Enjoy your googling! sumgai
monradon
Post by monradon on Apr 19, 2006 11:04:50 GMT -5
So this circuit was made passive and powered ??
Post by UnklMickey on Apr 19, 2006 12:23:53 GMT -5
So this circuit was made passive and powered ?? hi Monradon, if you read Flateric's post very carefully, i think you'll find, he was telling you there are 2 things that distinguish the EC Strat from a standard strat: 1 - the passive TBX control 2 - the active, battery powered mid-boost circuit. hope that helps. unk
monradon
Post by monradon on Apr 19, 2006 22:35:16 GMT -5
Thanks for the help guys my used body came today and guess what it was made for a tremelo and not hardtail so back to plan B or C
Post by flateric on Apr 20, 2006 2:00:24 GMT -5
EC (and others) block their trems cos they still want the springs - doesn't the legendary Eric Johnston also do this? - they add some resonance and sustain to the tone. My preference would also be for a blocked trem rather than a hardtail, so your plans should not be thwarted!
